	This is a sticky topic.
 Any thoughts on fitting 15x8 et 7 all around on an 89, with a mild roll front and rear already?
 On BC coils and can adjust camber front and rear; I think the only worry is fitting a tire around 205 (dont want to go smaller) and possible caliper interference. The wheels lips are 82mm, so I'm betting its close to the caliper.
 Thanks,
 GComment
 Won't work, it would rub near constantly. Only choice for those is 205/215s, and it would look very strange unless the car was low.Comment
 Would look and work great with 205/50s.Any thoughts on fitting 15x8 et 7 all around on an 89, with a mild roll front and rear already?
 Thanks,
 GComment
 Hey mystikal
 do you think a 16x9-5, and a 16x10-5 would fit without having to pull the fenders and about -3- -4 degrees of camber? i don't think it would, just looking for an answer from someone who knows alot about wheel fitment on e30's99 Honda Prelude (The headache)
 91 $400 dollar 318is ;D http://www.r3vlimited.com/board/showthread.php?t=304563Comment
 Wouldn't work. You want the front and rear offsets near +10 for 9s/10s.Comment
 I have a 91 318ic with H&R drop spring, 1 dead coil cut off and e90 drop hats. I'm picking up a set of style 19's (17"). What I was wondering is, whats going to be involved in making these wheels fit, what size wheel adapters will I need (15mm,18mm,20mm,etc.). What size tires can I run? Will I have to roll the hell out of my fenders? Any help would be great!Comment
 The smallest adapters available, which is usually 18mm. Yes, lots of fender rolling and 205/40 tires. It'll still probably rub a little bit.I have a 91 318ic with H&R drop spring, 1 dead coil cut off and e90 drop hats. I'm picking up a set of style 19's (17"). What I was wondering is, whats going to be involved in making these wheels fit, what size wheel adapters will I need (15mm,18mm,20mm,etc.). What size tires can I run? Will I have to roll the hell out of my fenders? Any help would be great!Comment
