As an update to my previous question: I bought the 205/45/16 s.drives and they fit great. They actually have more sidewall clearance than the parada spec 2's... I guess s.drives and parada's both run wide? No clue. Anyway, for future reference they do fit with e38 style 5's running 10mm spacers all around.
	This is a sticky topic.
 Yes, you'll have lots of clearance. Use 205/45s ideally.Comment
 Flush is subjective. I'd also call either option flush depending on ride height and tire size.I have a set a wheels that are 17x8 and 17x9 +35 offset I wanna know what offset i can run to make the wheel flush with the fender. Some people say i can run 0 on the 8 wide and +5 on the 9 wide. I personlly was going to run +10 will that be to sunk tho? Does anyone know?
 You need to search for pictures.Comment
 Wheels come in two offsets 15x8 et 15 & 25. Wanted to run them on 225/50-15. Which will be the easiest to run on with out rolling if possibles. Tire size input if rolling is required. Its a late model lowered on bav auto springs & kybs. ThanksLast edited by Chessmaster; 01-14-2014, 08:08 PM.Comment
 I would like to run XXR 531
 16x8 et0 up front with a spacer
 16x9 et0 in the back no spacer
 What tire should i put? I chose the 9s in the back so I can put some tire on it..
 Car will be lowered on coilovers, I would like a little bit of stretch but not too much
 ThanksLS1 91 325i - BC Coils, e46 m3 brakes,style 32 17x9, Red Plastidip, H/C/I
 If you want to run 225/50s you'll need to buy the +25 version then use 5mm front spacers to clear the struts.
 The no-spacer option would be +15 and 205/50s.Comment
 The offset is too low, the wheel will be poking front and rear.I would like to run XXR 531
 Thanks
 For what you want +20 front and rear with the same widths is ideal.Comment
 Neat. Did I see your car on reddit yesterday? The fitment seemed familiar.As an update to my previous question: I bought the 205/45/16 s.drives and they fit great. They actually have more sidewall clearance than the parada spec 2's... I guess s.drives and parada's both run wide? No clue. Anyway, for future reference they do fit with e38 style 5's running 10mm spacers all around.Comment
 I found some nice rims, size 16x8 et20 front, 16x9 et15.
 I would like some poke, just a little bit, do I have to run spacers for that?
 What tire should I mount to have some stretch? Would 225/40 rear 205/45 front look nice?
 Thank againLS1 91 325i - BC Coils, e46 m3 brakes,style 32 17x9, Red Plastidip, H/C/I
 Those are good wheels for that. Mount them as is, you might add a front spacer later but I think you'll be happy. 205/45 front and either 215/45 or 225/40 works. Or 205/45 all around.Comment
 I'm sure the question has been asked before, but a search of the forum does not yield a clear answer...
 What is the exact size of 17" BBS LM I need to fit properly on a 1992 E30 convertible? No aftermarket body kits/updates. The suspension is currently stock, but I am planning on Bilstein shocks with H&R springs in the near future.
 Also, any idea where to find a set finished in gold with a polished lip?
 Thanks for any and all help!Last edited by DMSBimmer; 01-19-2014, 09:32 PM.Comment
