This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #7351
    Originally posted by keefy6
    great, thanks again this size tire isn't too tall or too thin right? looking to fill the wheel well.
    No
    • Bullwings
      • Feb 2012
      • 83
      #7352
      I'm guessing this is pretty standard fit, but i'm looking at
      15x8 +25 with 205/50 (i'm currently on Style 10s, 15x7 +24)
      Fender rolling needed? I'm on Billy Sports with H&R race. Offset FCAB for some camber, that's it. Otherwise unremarkable. It's mainly a DD with some canyon runs and an occasional auto-x.
      • getouth
        • Jan 2010
        • 3343
        #7353
        I'm not Mystikal, but from the looks of those specs you will be fine.
        FEEDBACK:
        http://www.r3vlimited.com/board/showthread.php?t=316212
        BMWCCA #398608
        IG @yagayo38
        "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
        • blue plates
          • Feb 2014
          • 580
          #7354
          Can porsche fitment 5x130 wheels be drilled and filled to fit a 4x100 car? I was told it was t possible by rotiform, just wanted to check here as well.
          Originally posted by IRON-E
          Yeah, you're definitely a vw
          • scotte30
            • 65
            #7355
            any insight on 16x9.5 et 15 (after adapters)?
            Bilstein sport GC coil over kit 450f, 700r
            late model fenders, rears rolled
            currently run 15x8 et 17 with 225/45 no problem
            I'm hoping to run either a 215/45 or 225/45 on the new wheel setup
            s50 | e30
            • leRodrigoCruz
              • Feb 2014
              • 42
              #7356
              I'd like to know whats my limit before having to pull the fenders, mind you the car will be
              on air suspension.
              I was thinking and please do advice, 16x8.5 Fronts 16x9.5 Rears I am not too sure of what offset the wheels should be given the sizes. Also tire sizes, I know a lot of you here aren't into this form of fitment but any advice would be greatly appreciated.
              • blue plates
                • Feb 2014
                • 580
                #7357
                Rodrigo, what're the offsets on the wheels and are you going with a slim bag or double bellow?
                • leRodrigoCruz
                  • Feb 2014
                  • 42
                  #7358
                  I'm doing Airlift Performance series struts with double bellows, I don't know what offsets to do because I am getting a set of 3pc rotiforms built for the car and I haven't ordered yet because I don't know what offset to run before I have to do major body work. I really don't want too.
                  • Mystikal
                    • 9602
                    #7359
                    3mm front spacers, otherwise good to go.
                    • Mystikal
                      • 9602
                      #7360
                      Fronts will likely to get down to +7 or so to clear the front perches. If you keep the rears at +15, 205/45 front 215/45 rear is possible.
                      • Mystikal
                        • 9602
                        #7361
                        on air suspension.
                        +5 all around. 195/45 front 205/45 rear.
                        • anabolice30
                          • Jul 2013
                          • 946
                          #7362
                          If I were to get Salad shooters and 5x120 adapters, would I need longer wheel bolts or would the stock ones work? I have extra wheel bolts laying around.
                          Also the tires on the wheels I'm looking at are 255/50 would I need to roll my fenders? And anything else that goes into installing these wheels I'm not aware of?
                          • Mystikal
                            • 9602
                            #7363
                            Not nearly enough info for me here.
                            • Scruggs
                              • Mar 2014
                              • 23
                              #7364
                              Thanks mystikal, for sharing your wisdom, sorry if I leave any important info out, I'm new to this. I'm looking to get staggered borbet type a's (16x7.5 et15 in the front/16x9 et20 rears) for my 91 vert. I'm about to go through the suspension, and will probably go with billy sports and h&r springs for about a 1 1/4 inch drop. My question is what tires and spacers should I run to fill everything out nicely? (I don't mind rolling my fenders a little, and I am not a fan of stretch)
                              • Julien
                                • 7471
                                #7365
                                Offset: 40mm
                                Backspacing: 6.26"
                                Bolt Pattern: 5-120
                                on e36 m3 5 lug, late model, bavauto springs, rolled fenders. possible with 215/40 S-drive?
                                will be running whatever camber I can run with shims up front
                                Build Threads:
