	This is a sticky topic.
 Hey,
 Sorry for asking again, but the previous wheels I wanted to buy are gone, but I found some new ones.
 My car is a late model '89 E30 318.
 The wheels are same as before, Keskin KT4, but they are 16x7,5 ET35 (all of them), currently on 195/45R16 tires.
 What size of spacers do I need? Any fender roll? Will it work at all? :D
 Thank you for your further advice, and also for your patience.
 DanielComment
 I'd suggest 15mm front and 20mm rear spacers. Replace the tires with either 205/45 or 205/50 once they're worn. No rolling.Hey,
 DanielComment
 I have a 1988 Super Eta running H&R sport springs and Bilstein sport shocks, with no spring pads in the front. Looking at running a set of 16x8 Style 5s. What tire sizes would be available, both with and without rolling the fenders. I don't want to run any fill/drill wheels, so adapters are needed. Thanks for your help!!1993 Alpine White II 325i convertible (last year of E30 production)
 1988 Zinnoberot 325 Super ETA coupeComment
 Hey, sorry, just need a bit more clarification on this. Rolling needed or not?I'm guessing this is pretty standard fit, but i'm looking at
 15x8 +25 with 205/50 (i'm currently on Style 10s, 15x7 +24)
 Fender rolling needed? I'm on Billy Sports with H&R race. Offset FCAB for some camber, that's it. Otherwise unremarkable. It's mainly a DD with some canyon runs and an occasional auto-x.
 At what point would I need rolling? with another 3mm spacer, that would make the wheel at 15x8 +22.
 Does a 15x8 +20 need rolling?
 Thanks in advance.Comment
 I picked up a '90 325is with Ground Control's street/track coilovers, and I'd like to know if you're aware of how wide a wheel I can run in a square fitment with no fender pulling using 225/45/15 BFG Rivals and with what offset. The Miata guys run them on 9" wide wheels, but I don't think those clear late model rear fenders without a roll & pull, and my measurements show I'd need +12 to +15 offset to clear the front struts. 15x8 +20 would be safe, but the tires yield more grip when mounted on 15x8.5s or 15x9s.Comment
 What size tire should i put on my O.Z turbos the car will be on the will be on gc coil overs with 550/600 springs. Im thinking like 175/50/15 the wheels are 15x7 btwComment
 18mm adapters, 205/45 tires, rear fender roll. Or 195/45 tires and no roll.I have a 1988 Super Eta running H&R sport springs and Bilstein sport shocks, with no spring pads in the front. Looking at running a set of 16x8 Style 5s. What tire sizes would be available, both with and without rolling the fenders. I don't want to run any fill/drill wheels, so adapters are needed. Thanks for your help!!Comment
 No rolling all the way down to +20 (with 205/50s).Comment
 8" is the practical limit. But if you want to push it, 15x8.5 +17 could just work with a rear fender roll and front camber plates.I picked up a '90 325is with Ground Control's street/track coilovers, and I'd like to know if you're aware of how wide a wheel I can run in a square fitment with no fender pulling using 225/45/15 BFG Rivals and with what offset. The Miata guys run them on 9" wide wheels, but I don't think those clear late model rear fenders without a roll & pull, and my measurements show I'd need +12 to +15 offset to clear the front struts. 15x8 +20 would be safe, but the tires yield more grip when mounted on 15x8.5s or 15x9s.Comment
