This is a sticky topic.
  • Liquidity
    • May 2014
    • 395
    #7591
    Originally posted by Mystikal
    I'm going to go ahead and leave this here:
    0 offset wheels that are 8" wide or more have no place on an E30 without HEAVY fender work aka pulling/flaring. I'm not even answering these posts anymore. :)
    Now on to the rest...
    I've seen lots of wheels in this thread and the stance thread that work out to an 8+0 offset and fit. You were talking about a 9+0 that only needed minor fender work a few posts before this one.
    This guy is running the equivalent of 8+0 front and 9+0 back in 17s and I don't see any modification. I surely can't imagine a 15x8+0 is going to need any modifcation at any ride height.
    • bubbajan21
      • 1962
      #7592
      Need some advice on tire fitment. Im running E30 M3 5-lug conversion on a standard body late model E30. I need to replace my rear tires and I'm wondering if you have some advice on going a little wider (The fronts will not be not changing). The rears are 18x8 et35 with a 3mm spacer, 215/35/18 no rub anywhere, fenders are NOT rolled and will not be.
      I'd like to put 235/35/18 on the rear and I can keep or remove the 3mm spacer to give clearance on whichever side I need it. For reference, I had 215/40/17 on a 17x8 et20 on this car and the rear touched the fender lip and cut a groove into it (never ran them, way too much contact even at parking lot speeds or not moving).
      Do you think I could fit the 235/35 18's on the rear? Any issues with inner clearance if I remove the 3mm spacer to gain some fender clearance? Any diameter problems since these are a little taller? Any other considerations?
      Let me know what you think!
      Thanks in advance
      • Mystikal
        Wheel Fitment Expert
        • 9602
        #7593
        Originally posted by ninekrpm
        Looking to run a wider tyre in the back - currently running 205/45/17 squared...
        anyone running 17x8 on 205/45/17 front and 225/45/17 (this will cause .5" larger diameter in the back; but size options are limited).
        Need to know your offset, but no 225/45 doesn't work well.
        • Mystikal
          • 9602
          #7594
          Front: 16x7.5 et13 - 185/55/16
          Rear: 16x8.5 et25 - 215/50/16 (prefer oversized if possible in the rear)
          Non-M e30 running e30 m3 fully adjustable GC coils. 450f/650r. All corners rolled flat
          Should fit. No idea what kind of tires you're going to find in those sizes though.
          • Mystikal
            • 9602
            #7595
            Originally posted by 928*dog
            My bad, the offset is +40 and they have Lexani Tires on them, does anyone have exp with this brand? Thanks in advance!
            Cheap, Chinese wheels with cheap, Chinese tires on them. And they won't fit an E30 without $200+ in spacers, bolts, and hubcentric rings.
            Just run away.
            • Mystikal
              • 9602
              #7596
              You're welcome to try.
              • Mystikal
                • 9602
                #7597
                Thanks in advance
                Yes. Your offset is so high it should fit fine.
                • LJ851
                  • 7918
                  #7598
                  I see you imagine a lot of things.
                  Lorin
                  The M30 is God's engine.
                  • keefy6
                    • May 2011
                    • 991
                    #7599
                    Originally posted by keefy6
                    Mystikal, I found a unique set of 15s, here are the dimensions rqst help again;
                    15X9.5
                    4x100
                    there is an option for offset, which is best 15 or 25? I'm thinking 15?
                    And which tire would be best?
                    Spacers needed?
                    15, and you'll likely need 10-12mm spacers for the fronts to clear the struts. 205/50 tires.
                    will these poke or no? would 15x8.5 be a better fit?
                    My old Style 5 Thread / My Swap
                    1991 318IS :bow: 2.5L S14 Swap/BC Coilover suspension/Some new (old) wheels/
                    IS Skirt-Lip/RG Splitter/M-Technic I Spoiler/Dogleg/3.46 Diff/Euro H4 headlights etc.
                    1998 528I (Sold) // 2003 540I ///M Sport
                    • Liquidity
                      • May 2014
                      • 395
                      #7600
                      I see you waited to troll until after mystikal posted. You're like the scrawny wimp with the big mouth that hangs out with all the tough guys.
                      • 928*dog
                        • Jun 2014
                        • 4
                        #7601
                        Just run away.
                        How much more clearance do i need to make them work? I'm not racing or anything and i can get ahold of some sparco spacers for 50-90 depending on how thick they need to be..
                        • WineCountryE30
                          • Aug 2012
                          • 53
                          #7602
                          Hello everyone!
                          I am an engine guy and this wheel ET offset talk is more than a little confusing for me. I did my homework but I need a learned opinion.
                          I just bought a set of 7x15 5 lug wheels, Max399’s hub adapters, sourced some E46 hubs and calipers off a 325i sedan and some E36 Z3(I6) rear hubs and calipers.
                          The front offset is 12mm and the rear offset is 23.2mm. Its on Stock springs and I would like a stock flush look. The wheels have an ET of 47.
                          So if I am doing this correct the front would be ET 35 and the rear ET 23.8
                          Tire size is currently 225/45/15
                          Will this set up work on my E30? Do I need to use spacers? Should I use 12mm spacers in the front to get the same offset as the rear?
                          Any advice would be welcome
                          1991 BMW 318i - Parts Gathering for MZ3 5Lug and M62 Swap
                          1966 Triumph Spitfire MK2 - 95% Restored
                          1976 Jeep CJ5 Renegade Levi's Edition - 40k OG Miles
                          1991 GMC 2500 - Factory 454SS
                          2008 Honda Pilot
                          1957 MGA Coupe - Only the Body and Frame right now
                          • HarryPotter
                            • Jan 2010
                            • 3642
                            #7603
                            Lots of cheap tire choices in 195/45/16: www.onlinetires.com I'd recommend the $50 Federals.
                            You are a sweetheart.
                            John F. Kennedy
                            • Mystikal
                              • 9602
                              #7604
                              They'll poke horrendously in my opinion.
                              8.5" is the limit to fitting 15" wheels inside the front fenders.
                              • Mystikal
                                • 9602
                                #7605
                                15-20mm will work.
                                Please don't do it.
