	This is a sticky topic.
 You flatter yourself. I didn't put nearly that much thought or effort into my response.
 I speak from experience with 15X7.5 et 25 on my unmodified car. No way could i run 30mm spacers, not even close.
 But don't listen to me, listen to mystikal.Comment
 What tire sizes would work best for this
 I'm looking at 16x7 +22
 I have H&R race springs, and am looking for a meatier looking tire (not a fan of the lo-pro look). Would something like 215/50/16 work?Comment
 Do you say this because it could be a potential safety hazard, or because you think i should buy different wheels just to make it easier? I'm only paying $400 for everything and the tires have 90% tread i'm trying to figure out if i can make my ride look clean and get rid of the shitty hubcaps it currently has along with the 14's  Comment
 So, is your new goal on this forum just to talk shit in as many threads as possible?
 You don't come off as knowing what you're talking about. You come off as a dickhead.
 Give it a fucking rest.Comment
 I looked back at my recent post history and i see a pretty small percentage of abuse/sarcasm posts but i can't have you thinking i'm i dickhead josh, i'll clean things up.Comment
 I'm looking to pick up a set (17x8 et20) and have them redrilled to 4x100 will they clear one of Massive's bbk's? and if not what size spacer do you believe I'll need? Can I fit 235/40/17's?Comment
 You're too low for 215/50 to clear well. Use 225/45/16 for the best combination of sidewall and tread. Or 205/50, still big and bubbly.Comment
 That's $400 too much. They're very poor quality wheels AND tires that won't even fit your car without another $200 in hardware. Why spend $600 on trash? Seriously, buy something good. You'll be much happier in the end.Do you say this because it could be a potential safety hazard, or because you think i should buy different wheels just to make it easier? I'm only paying $400 for everything and the tires have 90% tread i'm trying to figure out if i can make my ride look clean and get rid of the shitty hubcaps it currently has along with the 14's Comment
 Massive sells several kits from tiny to gigantic. Either way brake clearance is determined by the rear of the wheel spokes and not fitment spec so I have no idea. 235s won't work on those wheels.Comment
 Was wondering if on a late model 16x7.5 et25 wheel with a 225/50/16 tire will clear in the rear with a fender roll? I have read the optimal size is 225/45/16 but i have a set sitting in my garage that are in good condition i would like to use if possible car is lowered on ST lowering springs. Thanks for the helpComment
 Haha thanks
 It will rub on larger dips. I mean if you have them laying around, I'd try it personally.Was wondering if on a late model 16x7.5 et25 wheel with a 225/50/16 tire will clear in the rear with a fender roll? I have read the optimal size is 225/45/16 but i have a set sitting in my garage that are in good condition i would like to use if possible car is lowered on ST lowering springs. Thanks for the helpComment
