	This is a sticky topic.
Why don't Beyern Mesh rims fit my IX???
Why do the Beyern Mesh 17x7 4x100 ET27 rims fit the 325i and not the 325ix???
Is it the struts? I'm getting a complete ground control coil over system for my ix so will that change the situation?
I'm totally stuck on those rims so what do I need to do to make them work besides getting an i...or will the ground control conversion solve my problem?Comment
Borbet Type A
I've purchased a staggered set Borbet Type A (16x7.5 / 16x9) I'll be running catuned coilovers so I can adjust my ride height. Rear fenders are already rolled Looking for help with tire size and do not like the stretched look. I'm looking at:
205/50/16 or 205/45/16 up front
225/45/16 or 235/45/16 in rear
Thoughts guys, 99% of my driving is on the streets and I'm not looking to be
2" off the ground. The car is just a play toy. Don't know if it makes a difference but I have a s50 swap as wellComment
They definitely fit. No mods necessary. Use 205/40s to ensure no rubbing.Why do the Beyern Mesh 17x7 4x100 ET27 rims fit the 325i and not the 325ix???
Need the offsets.I've purchased a staggered set Borbet Type A (16x7.5 / 16x9) I'll be running catuned coilovers so I can adjust my ride height. Rear fenders are already rolled Looking for help with tire size and do not like the stretched look. I'm looking at:
Hey, I'm about to purchase a set of wheels for my 89 coupe and wanted to see if they will fit. 17x9 et20 front, 17x10 et20 rear and the other set is 17x9 et33 and 17x10 et33. Rear fenders are pulled and shaved. What are my options? ThanksComment
With a lot of stretch they can work. First set needs 5-8mm front spacers. Second set 20mm front 12mm rear. Ideal tires are 205/40 225/35 staggered.Comment
Looking into some wheels wondering if these would be able to fit an E30?
Specs: 16x8.5
+22 offset all around (square setup).
Thanks!Comment
You need 5mm front spacers to clear the struts. Otherwise good to go. 205/50 should just barely clear without rubbing. 225/45s will require a fender roll, and front camber plates for a little extra tilt.Comment
