This is a sticky topic.
5mm front spacers, and shorter tires. 215/50 or 225/50 would work. The sizes you put are too tall.hi i was wondering if a set of 15x8 et25 with 225/55r15 or 215/55r15 will fit a 89 coupe on mild lowering springs (going for an old school street racer look so it doesn't matter if they stick out a little)
these are the wheels http://www.ebay.com.au/itm/15x8-Axis...16.m2518.l4276Comment
Yep. Good tire choices.Ive got a 1990 325ix dropped apprx 1.5" from stock currently with oem 15x7 et41 basketweaves on 195/65/15s. Will my ix fit 15x8 et25 konig widopens with 195/55/15s or 205/50/15s without hitting the struts or wheelwell liner or having to roll the fenders?
Thanks for readingComment
I have a 91 325i, ls1 swapped, doing a 5 lug swap with z4 rear hubs (5mm+). I bought style 32 17x8 et20 17x9 et26, I am looking for what tire I can run.
I was thinking to run 235/40 r17 front and 245/40 r17 rears. they are both very close to each other and about 24.5" diameter.
Will it work fine?
I was looking at proxes r888LS1 91 325i - BC Coils, e46 m3 brakes,style 32 17x9, Red Plastidip, H/C/I
Fit question (2 different sets, same tire sizes):
205/55/15 (both sets). 1989 325 convertible lowered on H&R Sport w/ 15mm drophats up front.
Looking for info on fit of the following wheels:
15x7 ET10 (with 205/55/15)
15x8 ET20 (with 205/55/15)
Fit prognosis?Last edited by phenryiv1; 07-22-2015, 11:28 AM.Comment
Wow ace thread.
I have a 1989 325i coupe and I am new to mods.
I would like to lower the 60mm and 40mm and I would like to add borbet type A 16inch 4x100 j9 et15 all round.
Would I need to use spacers?
Will my wheels rub on anything?
Will the wheels still point straight?
Will there be any camber issues?
Will I need to use spigot ring things?
Hope you guys can help.
Js
Sent from my Nexus 4 using TapatalkComment
Z4 hubs? Isn't that E46 stuff? What about the fronts?I have a 91 325i, ls1 swapped, doing a 5 lug swap with z4 rear hubs (5mm+). I bought style 32 17x8 et20 17x9 et26, I am looking for what tire I can run.
Will it work fine?
I was looking at proxes r888Comment
First might rub occasionally front and rear. Offset a bit too low, but 205/50s would work. Second setup fits.Comment
3-5mm front.Wow ace thread.
Js
No.
If they did before.
If there were before.
If the wheels require them.Comment
I decided to go with Konig Tweakd 15x8 et22. Do I need some small spacers to get closer to et20, or should et22 be fine? Also would you recommend 205/50 or 205/55 tires? Lowered on Bilstein Sports all the way around, '88 cabrio.1988 E30 325iC
sigpicComment
Thank you.
Will I need spacers on the front because I am fitting 9js? If I was to fit 7.5j on the front would I still need spacers? Is it normal to fit 9js all round?
Thanks again great help. JS
