	This is a sticky topic.
 First ones are ideal with 205/50s. And need the hub rings to back it down to 57.1mm.89 325is with sport h&r and sport blistein shocks..im looking at 2 different set ups..
 first 15x8 4x100 offset 15 hub bore 73.1 and what size tire without stretching the tire too much...
 second 15x7 4x100 offset 25 hub bore 57.1 also please give me the same advice for tires...
 thanks in advance
 Second setup is great for big rubber. 225/50 is perfect.Comment
 Redrilled Style 5s huh. Yes, you will need 5mm front spacers if your brake pads are newish. 205/50 is perfect for what you're looking for. There's hardly a stretch at all, google for some imagery.Hey Jay tire size question + spacer question for you. Ok here's the setup:
 e30 convertible
 slight drop on h&r sports/bilstiens
 5x120
 16x8
 et23
 What's going to be the best tire size given offset and wheel fitment? My goal is the avoid fender rolling and avoid the stretched tire look while keeping as close to the original diameter - 24" as possible. My possible ideas are: 225/45/r16, 215/45/r16, 205/15/r16. I'm assuming I also may need a small 5mm spacer to pull this off to begin with.Comment
 Hey Mystikal you've been helping me through the years and I appreciate it big time!
 Just wanted to ask, would a 205/50 tire fit on a set of 16x7.5 et 13 without rub? What about if the offset was 21 instead of 13?
 H&R sports with Bilstein sportsComment
 Machined 5 Lug swap kit (Front out 12mm)
 I already have 235/40 tires, looking at 17x8 ET 45 with 10mm spacer in the rear? Any spacers in the front?
 On Billies/H&R Race springs
 Thanks!!The Lineup in order of appearance:
 91 535i
 91 318is 5 Lug/E46M3 Brakes
 91 325is w/ S52
 88 Vert Plastic Bumper Swap
 88 M3 ;D
 91 325ix 5 speed
 89 Vert Royalblau Metallic
 73 2002
 1986 325es --> is swap Rallycross Car!!
 1995 Chevy G30 Tow Rig... *I SOLD A CAR!!*
 1993 525i Granitsilber Metallic Touring
 Need a 91 M5 bad but wife would shoot me...twice
 *UPDATE: got a 93 M5 and still alive
 1972 Jeep Wagoneer
 1975 2002 five speed
 Check out:
 Elhartspeedshop.com
 sigpicComment
 16x8 Style 5 Fitment Help
 Hey Guys,
 I have a 1988 325 (super ETA) sedan. I'm pretty new to wheels/tires fitment.
 I want to run some 16x8 et 23 style 5s but don't want a fill n drill. So that leaves me with adapters. My questions are what adapters should I run and what sizes? What tire size would work the best for me. And what if any fender work will I need done. If anyone has some pictures for reference that would be great and any help is greatly appreciated!Comment
 You're very welcome. It will rub at +13, no rub at +21.Comment
 Assuming front out 12mm and rear same as stock: 8mm front spacer, 15mm rear. You will need front hub extenders to run this without vibrations.Comment
 You can, but it ends up SUPER aggressive. 18mm adapters, 205/45 tires, and lots of fender rolling. Or 195/45 tires and less rolling.Hey Guys,
 ASK ALL WHEEL/TIRE FITMENT QUESTIONS HERE - The Official Wheel/Tire Fitment T...
 Dr. Mystikal, I have a 1992 E30 convertible with stock suspension. I want to replace it with the H&R sport and Bilstein combo for a conservative, oil-pan friendly drop. I'd like to run 16x8 Style 5s with adapters. Really hoping not to roll any fenders.
 Questions: Which H&R sport springs are better, cabrio-specific springs or the coupe/sedan versions? What size adapters would I need? And what tire size options would I have?
 Really appreciate you giving your time to knuckleheads like me.
 Sent from my iPhone using TapatalkLast edited by Yogawrench; 08-21-2015, 06:47 PM.1993 Alpine White II 325i convertible (last year of E30 production)
 1988 Zinnoberot 325 Super ETA coupeComment
 Straight up won't work for what you're going for. Stick to wheels +15 or above, final offset.Dr. Mystikal, I have a 1992 E30 convertible with stock suspension. I want to replace it with the H&R sport and Bilstein combo for a conservative, oil-pan friendly drop. I'd like to run 16x8 Style 5s with adapters. Really hoping not to roll any fenders.
 Sent from my iPhone using TapatalkComment
 Hey man, thanks in advance for the help.
 I've got fzeros that are
 15x8.5 et 15
 15x9.5 et 15
 It's dropped in GE Coilovers with 2" sectioned in the front.
 Can you let me know if I'll need spacers as well as tire sizes?
 Thanks!sigpicComment
