	This is a sticky topic.
 15x8 +0 and 15x9 +0 with 195/50/15 tires all around on Coilovers with camber plates. Should that fit with a good roll? Don't hate on the stretched tires I'm planning on running a wide meaty setup on different wheels also.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
 Daily: 06 Chevy Colorado (wannabe racetruck)
 Drift/Track Car: 91 Bmw 318i 4drComment
 Worlds 1st LS powered e30 cabby.
 Cabbillac: 92 Lagunengrün cabriolet + cadillac LQ9 + Nitrous + rotiform SJC
 Raphael: 88 Lagunengrün IX + Hella 500's + Red ACS type 1's
 Shaggin Wagon: 01 325xiT 5 speed
 91 MR2 GT3076TS + E85 = 505whp + antilag = wheelies
 88 CRX OEM+ 42mpg DD.Comment
 Hey, i have a 1987 "335" with 325i suspension parts soon to have BC coilovers
 and i wanted to know what offset i have to choose for 16x9 up front and 16x10 in the back.
 Would et06 all around fit? The car has adjustable camber in the back.
 RegardsBMW E30 335i mtech1 '87
 BMW E36 325i coupe '93Comment
 Hey guys. At the moment I have 16*9 et 20 on the back and 16*8 et25 on the front, with 205/45/16 tires all around. I'm on koni sports (long) shocks and vogtland Springs. No spacers needed and I don't rub, but I do scratch my right back tire. This gives about a 2,5cm gap on the front and 1/1,5cm gap on the back (between wheel and fender). I would like to close this gap a bit more but I don't really want to spend money on new Springs as it is a really small gap. I have 2 questions :
 - how low can I go without rubbing and having fitment issues? If I scratch my right tire now, does that mean it will only get worse when lower?
 - what are your thoughts on cutting /compressing Springs? I know it's really not recommend for stock Springs but given that this are lowering springs already, and I only want to cut 1/1,5 cm, will it be that bad?Comment
 This is one of those situations that a cheap fix is not recommended. Clamping or cutting springs is never a good idea. I'd remove the spring pads and add drop hats if you haven't already.
 Sent from my iPhone using TapatalkFEEDBACK:
 http://www.r3vlimited.com/board/showthread.php?t=316212
 BMWCCA #398608
 IG @yagayo38
 "The Best E30's were built with two camshafts four cylinders and sixteen valves!".Comment
 I am going to be picking up some style 15 Bottlecaps very soon (16x7.5 et20) and I'm going to be running them with 18mm adapters. My fenders were rolled and pulled as much as possible to accommodate 16x9 wheels which were very impractical. I am on a bilstein sports/H&R drop. What is the largest size of wheels I can go?Comment
 Will 16x8.5 et0 work on a late model on h&r sports and Bilstein Sports? If so, whats the largest tire I can fit with this setup? Thanks!Comment
 Awesome man thanks! Just having a hard time finding suitable wheels here which is a bugger haha.
 Am I right in assuming given the above that with some 15x8 et25/(maybe even et15 if 25 is unsuitable) wheels I could run a square 225/50?(Also hard to find tyres in this size aha)Comment
 I have 1988 M3 Suspension on 1987 E30 Body.
 Currently I have: (My Ride)
 OEM 16x8 Style 5 wheels with 215/45R16 Falken AZENIS RT615K
 Looking at 17" Style 5 or other type wheels(light), tire selections are greater and possibility of BBK in the future.
 I have spacers on the car, not sure of the size.
 Fenders are rolled.
 What are my wheels worth $$ I have one spare never used, has rubber on it. 16 x 8
 Guy wants $950 for same basketweaves 17" x 8
 FB
 looks like 215 40 17 front and 205 40 17 rear
 no name brand tires, so pointless for what I want.
 Love to year thoughts
 Worried about fitment.
 I am leaning toward just new tires, and move on to other things in the engine bay.
 Mostly auto-cross, but would like to get back to the track, thus the braking need.1987 BMW 325is,(M3 S50 Swapped)-Current
 2010 FJ Cruiser, aka E30 Support Vehicle-(Daily)
 2008 Scion xB Lowered
 2001 BMW 325i
 1995 BMW 318ti
 1966 Ford Mustang Coupe
 1965 Ford Mustang Coupe
 My ThreadComment
