This is a sticky topic.
Works okay only because you're bagged. Fitment at static height would be too aggressive, but with bags you should have nice fender to lip fitment. I'd run 195/45 square.I have the opportunity to purchase some 16x7.5 and 16x8 et 11 BBS RS's 211 in a 5x120 bolt pattern. I have a set of 18mm adapters. This would bring the final offset to - 7mm. I am currently bagged.
1. Could these wheels fit without fender rolling or pulling?
2. Would fill/drilling the wheels be the better option?
3. What tire size would be most appropriate?
Thank you all for your help in advanced.
Sent from my iPhone using TapatalkComment
First one is best with a 205/55 or 205/50, second one you can fit up to 225/50 or 225/45.Looking to get these
15x8 et15
or these
With over 30 years of experience, MST Wheels is founded with the basic principle of providing the car enthusiasts around the world with top quality wheels at affordable prices. We now have flow formed wheels added to our catalog.
15x8 et20
on my 1985 318i. stock suspension for now but hopefully will lower an inch or so this summer. Which wheel would you recommend and what tire size? thanks!Comment
No spacers and 205/50 tires. Perfect fit.Comment
You sir are a saint! Might have a go with the 245/35/17 Toyo R1R.
On another note, what offset would you suggest to make 225/45/15's fit on 15x9 square?
How much massaging would be needed to fit the new 245/40/15 Hancook RS4 on 15x10 square?
15x9s suck, you have to space the fronts way out to +10 to clear the struts (larger wheels can get by with higher offsets due to the inclination of the strut). Fitment for real rubber will be impossible once you're out there.You sir are a saint! Might have a go with the 245/35/17 Toyo R1R.
You can surmise my opinion on 15x10s based on that. :D
I saw that new size. Will likely be THE hot ticket E30 size for those competing at higher levels. I can see people shoehorning them onto 15x8 +20 wheels (since there's so many of them, and a 245/40 fits well on an 8" rim) with pulled fender arches.Comment
In regards to this, having a 16x8 et20 wheel, is 205/50 tyre without stretch?
If i wanted to go with a with 225/40 or 225/45 can i use a similar offset without a spacer or what offset would you recommend ? As a reference these are the wheels i am looking
Also, I will have fortune auto coilovers with garagistics adjustable camber and toe rear subframe.
Thank-youComment
Hey. 325 touring on ground controls.
Impul silhouettes 17x8 et36 and 17x9 et36
What size adapters would I need front and back?
Tire sizes?
Is it possible to run this setup without rubbing? Will it require heavy fender work? Thanks in advanceComment
I'm usually a reader of this thread, love it. Thx everyone who's contributing.
Looking to get a set of track wheels/tires and wanted to get some input on tire sizes.
Any input on tire sizes for:
17x9 et30 front w/ 15-20mm spacer to clear strut
17x9 et30 rear w/ 5mm spacer
This would be on an early model w/ rolled fenders, 5x120 hubs.
5x120 swap results in about -10mm offset front & rear.
Currently running 16x8.5 et13 w/ 3mm spacer front, 16x9.5 et19 rear.
205/45 front
215/40 rear
Front pokes slightly but no rub.Last edited by pandaboo911; 01-19-2017, 04:56 PM.
Hi Mystikal, fantastic and informative thread, thanks for all your information! Just picked up an '88 325is and here's my desired setup:
Ground Control suspension - hoping to drop it approx. 2"
Looking to run all 4 wheels the same size, ESM-002r (either 16x8 ET20 or 16x9 ET15) most likely with a 205/50 or 205/45 tire.
Would either of those wheel sizes work for me without needing spacers or any fender rolling?
I would prefer the 16x9s for the deeper dish look, but if I will need spacers or fender rolling then I'd prefer the 16x8s.
Thanks for your help!!Comment
Hey man,
I'm fairly new on this. I'm pretty sure what iam about to ask has
Already been answered. But there's like 600 odd pages in this topic. Lol
I've bought some 17x9 et20 4x100.
Rear fenders have been rolled.
I knw they will fit. What tyres can I put on the rear and the front.
Was thinking 235 or 245 on the rear and maybe 225 on the front.
I dnt mind using spacers .Comment
