	This is a sticky topic.
 Hey Darien,Hey Jay - you are seriously the man for doing this for so long. I've read nearly the whole thing but that was while trying to fit other wheels :P
 I have an 88 vert and am now looking at:
 16x8 fronts ET25 - thinking 205-40s
 16x9 rears ET20 - in 215-40s
 I drive the shit out of everything. Am i in the game here?
 Darien
 The fronts are too high of an offset and will rub the strut housings. I'd go +15 there, and run either 195/45 or 205/45 tires. 205/40 will pop/bubble. Rears will work as is.Comment
 It'll rub with any more tire. The offsets are too low.Jay,
 Thank you for the response! Do you think it would be possible to run a 235/40 in the rear instead for more width/less stretch? I'm been looking at examples of e39 style 32s and I've seen the same specs tires suggested, but two have been running adapters (18mm and 20mm)and one running z3 rear hubs(+23)
 With the z4 hub it only pushes out 2.5mm. So my thought is I have between 15.5- 20.5mm more space between the hub and fender than the above mentioned setups.
 Also, could I run more tire in the front with the fenders rolled?
 Not a huge fan of stretched tires, but will deal because I like the wheels.
 Thanks!Comment
 With $200 worth of spacers and rings, yes. But just find similar in an offset between +15 and +25. They will bolt up then. There's like 500 factories in China pumping out those fakes you can find any size or offset, just search more.Comment
 +23 is ideal.So what would be the perfect offset on a 16x8 wheel front and rear to fit 225/45R16 tires
 I can roll the rear but is there an offset that would fit my car perfectly. 1990 325is.
 When I say perfectly I am not a fan of the poke I would like it flush, I will be running H&R sports.Comment
 You'll spend $300-400 on hardware to fit those flush. 25mm front, at least 30mm rear bolt-on spacers. IMO it's just not worth it.Comment
 So it's already rubbing pretty severely, and you want to run a tire that's like 2" taller? No, they won't even be close to working. Don't do this, buy wheels that fit.So 205/55r15s on 15x7.5 et0 wheels rubbed ever so slightly in the rear with a half assed roll (lips are bent to a 45° angle with a baseball bat). Still managed to get to the belts before cutting deeper than the letters.
 Now I wanna play offroad. if I finish rolling my fenders flat a 205/70r15 on the same rim should be good, right? What about 225/70?
 Looking at the new General Grabber AT3 that's coming out this spring. Comment
 No problem! Yeah I'm still here, sometimes not certain why, but hey I'm here!Well Mystical i didn't expect that you would be active after so many years! I mean you are beyond a forum moderator, you are a something like a doctor for the E30 enthusiasts that cannot find peace with their cars! I really admire you, i wish you the best my friend..!!!
 Well after many modifications i finally accepted the fact that 7x15 ET12 is not the correct wheel for the late facelift E30 i have. There is no way to use the car 100%. The look is fine but when two people stay in the back, or worse when you put things in the trunk and you have people in the back the rubbing is always here, no matter the height of the car. What pisses me off is that 205/55/15 tyres are more expensive than the 7X15 et12 wheels, so it is pointless to buy expesive tyres just to tear them apart after 100miles...
 The question is, sould i buy second hand original 15'' bbs 15X7 et24 or a new set of Ronal LS 15x7,5 et25 ? Is the fitment exactly the same? Do you have any opinion of the quality of Ronal LS or they are cheap made wheels?
 You see the whole point of aftermarket wheels is they have the beatiful lip aroud the wheel that the originals do not have....
 BR Mystical!!!
 15x7 +12 works well with a 205/50.
 Ronal LS are fantastic quality wheels. I'd buy those. You can even fit 225/50/15s on them.Comment
 5mm front spacers and you can fit a lot more tire than that. I recommend 215/40 or 235/40 all around. No rolling needed.Comment
 If you need to run adapters, the offset is already too low to work.All -
 Currently looking at running a 16x8 5x120 Et14 on a '92 E30Ic. Tire choice not yet defined, so feel free to add recommendations there as well. I will need to run adapters
 I'm looking for the wheels to be flush as possible, but not pokey - how would these fit, look, etc.?
 Car has bilstein shocks with eibach springs.
 Thank you for an insight and feedback providedComment
 205/45s would suit this fitment a lot better. It will still rub, and require a ton of fender massaging. But it's doable.Hello, on my 1989 e30 sedan was wondering if these offsets will be aggressive but not too pokey.
 Edit:
 Front 16x9 215/45 et5
 Rear 16x9 on 215/45 I've read et5 is flush.
 I'm running fifteen52 formula TRs.
 I know slight camber might be needed I have plates.
 Here is image I'm going for. Except he is 16x9.5 rear
 So eventually I will go bagged(not looking for static vs air debate!)
 But don't want the wheels to look to "donk" with my current height. Which is pretty low for springs
 Let me know thanks!Comment
 You should state what size spacers you purchased. If it's the recommend 3-5mm front only, then 225/45 will fit all around no problem.Enkei 92 15x8 et 25
 Planning on mounting these on to the car in the next few weeks. Car is currently stock height but will be installing m3 springs with hds, purchased the spacers, now just need the proper tire. I know many people run 205/50 but would 225/45 fit and not rub?Comment
 Awesome and rare. They should be +41 square off a Z3. 18mm adapters are perfect. I'd run 205/45 front 215/45 rear, personally.Came across a deal I couldn't pass up. Style 42's 17X8.5 and 7.5 staggered set. Currently has 245x45 and 225X45's mounted on them I think they are ET41 but they are not marked. I have a 1989 325I with H&R Sport springs and Bilstein Sports. I have the 42 Draft design 18mm 4 to 5 lug adapters. I am open to a mild fender roll if needed. Also open to e36 M3 struts. Any chance these will fit or what tire will fit or just dismount tires and run on my BBS RS's on my E24?Comment
