This is a sticky topic.
  • dave335
    • Mar 2004
    • 12
    #901
    Tire Size Help
    Hi Guys,
    Presently, I am running 7 x 16 Mille Miglia Evos with a ET37 and a 10mm spacer all around. The tire size is 225/45/R16 - Toyo Proxes T1S. When I took off the tires for winter storage, I discovered that I had major rubbing problems as I can see the tire essentially being shaved down the far right sides. Driving to back and forth to university (500Km away), I had quite a bit of weight in the trunk.
    I am thinking about ordering new tires. Based on tirerack, they recommend a 16" size of 205/50R16.
    Would this prevent any rubbing?
    Thanks in advance.
    David
    • Midnight Sun
      • Jan 2007
      • 429
      #902
      BTW Jay
      Thanks for the advice!!! It is really appreciated!
      Originally posted by Teaguer
      Filling an Eta's tank with super unleaded will reach the cars maximum attainable performance level .
      Aa a bonus filling the tank will also double any Eta's resale value .
      • Mystikal
        Wheel Fitment Expert
        • 9602
        #903
        Originally posted by dave335
        Hi Guys,
        Thanks in advance.
        David
        Where exactly was it rubbing? It should technically rub on the inside if anywhere, but even then I'm surprised it did. I ran a 16x7 ET25 225/45/16 (only 2mm further out) and never contacted a thing. Your setup should fit fine, but knowing where it was rubbing (front/rear, inner/outer) would help me diagnose the issue.
        Jay
        • E30trash
          Hella Flush
          • Mar 2006
          • 1873
          #904
          Originally posted by Mystikal
          Really? What coils? I know for a fact that a 16x8 will fit with even ET23, so you should have plenty of room unless they're some weird coilovers.
          Oh, and share the tire size you chose again. I don't remember nor care to search for it. :p
          Jay
          im running 195/45 tires.
          the stock spring perches were cut and the gc perches were welded much lower then the stock location. which works fine for me :)
          • dave335
            • Mar 2004
            • 12
            #905
            It was rubbing on the insides. Outsides were fine even without rolled fenders. I am lowered with Bilsteins and Jamex springs (garbage - soft) which could be a cause of the problem as they are soft. My fronts would rub when you turn the wheel lock to lock but this appears to be common on some vehicles. Not sure if it helps but the car is a 1985 325e 4 door.
            Thanks in advance.
            David
            • hugh jass
              • 2220
              #906
              215/40-17 or 235/40-17 on et20 17x8 style 42?
              e30 325 with e30 m3 5 lug
              i'm worried that the 235 will rub but the 215 will look too stretched.
              opinions?
              ______________________
              ex-Chief Operating Officer
              Blunt Tech Industries
              West Coast and Pacific Rim
              • Mystikal
                • 9602
                #907
                Thanks in advance.
                David
                It is the springs that caused it, and yes rubbing the splash guards on the front near full lock is expected with that setup.
                Backing down to a 205/50/16 should fix the problem, and if not then the springs are truly WAY too soft.
                Jay
                • Mystikal
                  • 9602
                  #908
                  opinions?
                  215 will be a slight stretch (nothing extreme at all), and 235 will not work without flaring.
                  Jay
                  • M42Technik
                    • 9781
                    #909
                    Jay,
                    With 17x8.5" definitely happening, hella flush fitment is ET16 front and ET06 rear.
                    But if I wanted to do correct sized tires, no stretch, what size tire and wheel offset should I shoot for? Will it even fit?
                    I only ask since the adapters I need will be custom and I want to get the widths right the first time since they're not cheap. ;)
                    EDIT: Smallest I can go on adapters is 35mm with the wheels so ET21 is the starting offset and I can go lower towards zero...
                    Reminiscing...
                    • Mystikal
                      • 9602
                      #910
                      Originally posted by M42Technik
                      Jay,
                      No stretch with those wheels would mean a 245/35/17. Which has no chance in hell of fitting with ET21 or lower.
                      So basically, you're stretching. The widest you can shoot for is a 215/40/17, which will already be close with ET21 stretched on 8.5 wheels. Or a 225/35/17 (FK452 or K104), which you can probably get away with ET15, just because it's so short.
                      Jay
                      • M42Technik
                        • 9781
                        #911
                        Jay
                        Hmm. I just want flush fitment with the wheels, the lip edges have to line up with the fender edges...much like Elliott and his D90's.
                        Dammit I dunno what offset will be the best for that.
                        EDIT: This is a 17x8" wheel ET12 -
                        I am getting confused as to what offset to pick! Gah!
                        Reminiscing...
                        • my325i
                          • Apr 2008
                          • 81
                          #912
                          Max backspacing??
                          What is the max backspacing before spacers are needed 15" wheels for 1987 325i
                          • Midnight Sun
                            • Jan 2007
                            • 429
                            #913
                            225/50/15 et20
                            • h82crash
                              • 127
                              #914
                              I saw a 325is with 17x7 et40 without spacers and they fit fine. Clearance at the strut was about .25". When spacers are suggested is it just to get the wheels closer to the fenders?
                              "Life is hard...it's a lot harder if you're stupid."
                              Tom
                              72 2002
                              87 327i
                              88 525i
                              88 535i
                              03 530i
                              • Mystikal
                                • 9602
                                #915
                                Well then you better get to stretching on some 205/40/17s. If you want to look agressive like these guys, you have to run skinny AND undersized tires. No choice really.
