This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #9406
    Originally posted by Chrisv006
    16x8 et23 e38 Style5's with 18mm adapters on 1990 cabriolet? I would like to lower the car with HR Sports.
    No, offset too low.
    • Mystikal
      • 9602
      #9407
      Originally posted by Buzz944
      Hey guys complete noob here
      How will these fit
      F 17 8.5 et15
      R 17 10.5 et22
      I have a feeling they're not gonna fit
      Depends on your concept of fit. With extreme rear tire stretch, it works. Needs either airbags or extremely stiff spring rates to pull it off, though.
      • Mystikal
        • 9602
        #9408
        Originally posted by rob-redm
        Hey there Mystikal,1986 BMW 325ES. I have a set of BBS LM's (real deal) 17 X 7.5 with a et 40mm off set... running a 205/45-17 Dunlop Direzza tire.. know I'm going to need spacers to make them clear the front and look right on the car (front and rear )due to the offset...and longer lug bolts also... car has a E30 Bilstein Sport Shocks - E30 (set of 4) T#3714 & H&R OE Sport Spring Set - E30 - 318is 325e 325i 325is M3 T#4342(the springs were rated at lower the car a 1"... whats your thoughts... Thank you...
        Well wanted to get the new rollers on my ES for the e30 picnic, went with H&R DR spacers 57.1 bore 15MM front spacers & 20MM rear spacers..my guess work came out ok... looks darn good !.. HMM do I keep my 15 BBS RS wheels as back ups... on the fence on selling those..
        That's exactly what I would have suggested. Good work.
        • Mystikal
          • 9602
          #9409
          Originally posted by cEm30
          im also wheel fitment slow.
          i have a set of BBS RZ469 16x8 et23
          i need 4x100->5x120 adapters.
          will 18mm adapter give me an offset of 5?
          Also anyone here running these of their e30 let me know what thickness you went with and why. thanks
          Offset too low, will rub.
          • Mystikal
            • 9602
            #9410
            Originally posted by mexocutioner
            Looking to get a set of IE3 springs with bilstein Sport shocks, combined with a set of trm c1 wheels 15x8 offset 20, and tires 225/50/15. From what I have seen other people have done this, but will I need rolling or pulling of the fenders to clear without rubbing?
            Yes, rear fender roll necessary. Still will be very tight.
            • Mystikal
              • 9602
              #9411
              Originally posted by elDizzle
              Fitment question: 16x7 et3 and 16x8 et-10 too aggressive? Tire recommendation if I can fit? On H&R sports + HD Bils. Thanks!
              Yes, too aggressive.
              • Mystikal
                • 9602
                #9412
                Originally posted by Deanoel
                Hi guys, looking at some 17x7.5 +15 offset (can choose a different offset if need be) running 205/40/17's, just stock suspension at the moment and guards aren't rolled. I want to avoid guard rolling and spacers if possible. Will I have any rubbing/clearance issues?
                Thanks for your help!
                No issues.
                • Mystikal
                  • 9602
                  #9413
                  Originally posted by grantmiller1
                  I'm the happy owner of a 1989 325i 2dr. Still running stock bottlecaps, but now I'm looking at getting new tires and going to 16" wheels.
                  I have Bilsteins on the front and rear.
                  I'm looking at getting Ronal R54 rims (16") and 225/50R16 tires. I'll probably go with Continental ExtremeContact DWS 06 tires, need good wet and dry performance here in the PNW.
                  Will this setup work/fit? Any spacers needed?
                  Thanks in advance !
                  Need to know the offset and width. Also, that tire size will not fit.
                  • Mystikal
                    • 9602
                    #9414
                    Originally posted by Vfrinterceptor
                    Mystikal-
                    Earlier this year in post #9191 you mentioned that the 245/40/15"
                    "Will likely be THE hot ticket E30 size for those competing at higher levels. I can see people shoehorning them onto 15x8 +20 wheels (since there's so many of them, and a 245/40 fits well on an 8" rim) with pulled fender arches."
                    I'm thinking of trying this as a autocross only combo for my car (1990 325i, IE3 springs, Billies, urethane bushings, front GC camber plates, Z3 rack) and was wondering how much the front and rear arches would need to be pulled?
                    Thanks for the longtime contributions to the community through this thread!
                    Not certain to be honest. It would be best to start with a higher offset wheel, such as a 15x8 +25 all around. This way you can run a 5mm front spacer to clear the struts and no rear spacer for maximum clearance. I'd guess only a basic front and rear roll would be necessary with this setup.
                    • Mystikal
                      • 9602
                      #9415
                      Originally posted by Sale30
                      What will be the best Tyre size to fit on 17x7.5 ET28 to fill up the gap with the fenders on my 4D 320i 1985? I have D2 Racing full coilovers not yet installed, I was thinking to go with 225/40/17 or 215/45/17 I think the 235/40 is going to be wider than the wheels edge and might cause too much rubbing with the fenders but anyway I'm planning to roll my fenders to give more space for the Tyre to go inside freely.
                      I'd go with 235/40. They will fit.
                      • Mystikal
                        • 9602
                        #9416
                        Originally posted by Blamfam
                        If my searching served me ok:
                        '86 325e, basically stock.
                        I have acquired 4 DS2's 17x7.5.
                        Go with 20mm adapters and 215/40 tires?
                        Yep.
                        • Mystikal
                          • 9602
                          #9417
                          Originally posted by Project_e30zuse
                          Just bought my first e30 its a 1991 325i and it's bone stock for the moment. Looking to turn this into a major project but wanted to know if I could run 15x8 4x100 0offset fronts and 15x10 4x100 0offser in the rear on stock suspension.
                          Will I need to roll my fenders? Do they fit ? Any not to expensive coilovers someone could recommend?
                          Not even close. Same wheels in a +15 front and rear have a chance.
                          • Mystikal
                            • 9602
                            #9418
                            Originally posted by Mazin
                            Hello
                            Need some help with some tires to go on these borbets
                            Car is fully stock
                            1989 convertible e30 325
                            Can someone help with tire size to go on these rims with out rubbing?
                            Offset?
                            • Mystikal
                              • 9602
                              #9419
                              Originally posted by Hershwon
                              Hi Just got myself a 1985 E30 323i Baur TC
                              Looking at getting some JOM coilovers.
                              Wondering how a set of 16x8 et20 up front and 16x9 et15 would fit. Would I need spacers? Also what tyres would work?
                              Other option is 17x9 all round et20 would that work all?
                              Thanks in Advance.
                              Brad
                              Go with the 16s. No spacers and 205/45 tires all around. Can also do a 195/45 up front for a matching stretch look.
                              • elDizzle
                                • Dec 2015
                                • 111
                                #9420
                                thank you!
                                You're the Man! You just saved me a ton of money!
                                92 325i Calypsorot Convertible
                                H&R Sport Springs+HD Billies+E90 Drop Hats
