	This is a sticky topic.
 17" and up wheels are easy to fit even with unsuitable offsets, because the struts are angled inwards towards the top of the car. While a 17x7 ET40 works, a 15x7 ET40 will definitely contact the suspension.
 That said, I still suggest spacers not only for appearance sake, but also to maintain the proper steering geometry. You can radically change the handling of a car when you run wheels with offsets that far off.Comment
 Thanks Jay, I'm not worried about running small tires, its the offsets that are important. After looking at some other wheels ET16 looks perfect for the front and ET06 may work in the rear. I just don't want the wheels poking too far out past the fenders either.
 I saw ET16 on a 15x8" wheel on an E30 and it looked just about flush...Reminiscing...Comment
 I'm looking at 2 sets of wheels and trying to decide which set to buy. The first set is 4x100 15x6 et38 and the second is 6.5 x 15 ET17 4 x 114.3. They are both RSs. I'd like to run probably a 2" lip on either set. Would I be better off buying the et17s and having them redrilled to 4x100 or buying the et38s and running spacers? Thanks!!__________________
 1987 Toyota Landcruiser V8Comment
 If you're going to widen them, getting the first set would be advisable. I'll explain why.I'm looking at 2 sets of wheels and trying to decide which set to buy. The first set is 4x100 15x6 et38 and the second is 6.5 x 15 ET17 4 x 114.3. They are both RSs. I'd like to run probably a 2" lip on either set. Would I be better off buying the et17s and having them redrilled to 4x100 or buying the et38s and running spacers? Thanks!!
 First set widened: 15x7.5 ET19 (which is perfect)
 Second set widened: 15x8 ET-2 (which will poke WAY outside the fenders)
 ...and you'd still have to redrill the second set, which is always a risk. Hell, I'd go for even wider lips on the 15x6 ET38s, those are perfect for deep dish (they are close to the inside of the car, leaving all the room you want for big lips on the outside).Comment
 The good news is you won't need any spacers to just mount them up right now. If you want them to really look good though, 15mm hubcentric. And change the tires to 215/40/17 when they wear out.Comment
 15x7 Euroweaves
 I have a set of 15x7 Euroweaves and I am looking to put 225/50s on them for my 86 eta. However the guys at Discount said that the max width is 205 which I doubt but I figured that I would make double sure before I ordered the tires. No suspension mods yet. I am looking at the Falken ZE-912s.Comment
 I dont do much as far as 15's or stock suspension, but even in a 225, that make of tires will still be narrower than other 225's. The front is where I would be worried about snagging a fender.sigpicComment
 Im finding it hard to find info on bbs and oz racing wheels anyone else have this kind of trubble?
 Anyways i noticed that the bbs LM come in 17x8 and wanted to know why no one has them. cos obviously if they fitted the e30 a few people would have them. Is there a way to make them fit?
 Thanks MassimosigpicComment
 Hm....
 wouldnt it be beneficial to make a table or some guide, what would fit e30 without any mods, and what would require fender rolling...
 eg. 17x7.5 wheel will require et20 and up to 215x40x17 should be sweet without rolling...
 than say 16x8 will require etXX tires xxxXxxXxx will require rolling, etc....
 or a tleast rough guide ?
 cos i see people asking the same questions all the time....Comment
 On the iS or the M3? Without M3 fenders, it depends on the tire. For example, on a 7.5" wheel the BFG KDW is only 9.0" wide, while an RE050 is 9.3". The KDW has a good chance of working, but the RE050...not so much. In either case it would just be a simple roll, nothing huge.Comment
