Originally posted by akorcovelos
View Post
This is a sticky topic.
Originally posted by akorcovelos View PostGreat info, thanks. Would those be a stretch fit? This is one of the most helpful threads EVER! Oh, and I think that was the 1001 thread :p
Originally posted by fourcylsgood View PostHere's a new fitment for the Spec E30 guys
15x7 +10
Now, for Spec E30 the target tire size is 205/50R15 so I can see that working without necessarily having to roll fenders. (Not that the Spec E30 guys care but I do at the moment). But would 205/55 also work or does a 7" +10 require an undersized tire to avoid fender rolling?
Originally posted by Rob@UUC View PostInteresting - no fender modifications? This is really quite the chub of a tire, I'll have to take pics next to the 225 Dunlop.
- Rob
Originally posted by AriasATX View PostThanks a bunch!!
I prefer the Euro flush look and as much width as possible as the car will be putting down 400+rwhp. Rolling the fender's isnt a problem. Also to note. The car will be on GC's with adjustment plate's and Koni's before these go on. Will the fitment become an issue? Oh and im going 17x8 all the way around. They dont offer the 17x9 in the BP needed.
With that much power, go for a 17x8 ET26 all around and wrap them in 235/40/17 tires. You'll have to do a mild fender roll at the most, and you'll have lots of rubber on the ground. It will also look VERY aggressive.
Originally posted by akorcovelos View Postforgot to ask, won't it be weird to have a 40 series in front and a 35 series in back? that would make the o.d. greater in front that back?
225/40/16 and 245/35/16 are almost the same height. 215/40/16 and 245/35/16 are actually identical in height, if you really want them to match.
Question- I am looking to get a set of 17x8 inch wheels. I can pick the offset. What would be the optimal offset and tire size? I am currently s52 powered so I need all the tire I can get back there without having to do a lot of flaring.
I am on H&R Race springs and Bilstein Sports, I have the ability to raise the rear of the car up an 1/4-1/2 inch with plates I had made.
Thanks,
JeffLast edited by BlackE30; 05-01-2008, 10:55 AM.
Originally posted by Mystikal View PostNah, read this link on how tire sizes work (scroll down to the sidewall aspect ratio section): http://www.tirerack.com/tires/tirete....jsp?techid=46
2012 MCSCC/NSSCC CP class champ
HSAX Instructor
Originally posted by Mystikal View PostUnfortunately the flush look and tire width go together like oil and water.
Originally posted by BlackE30 View PostQuestion- I am looking to get a set of 17x8 inch wheels. I can pick the offset. What would be the optimal offset and tire size? I am currently s52 powered so I need all the tire I can get back there without having to do a lot of flaring.
Thanks,
Jeff
I'm going 17 x 8 et 25, with a 235/40/17.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
Posting on behalf of a friend:
Hi Mystikal,
I am running H&R Race / Billy sports on the E30 318is at the moment, no front spring pads, but still the usual not-low-enough stance with the 4cyl.
Also recently acquired Borbet A’s in 16 x 7.5 ET20. Some tire sizes in question are:
205/45R16
205/50R16
225/45R16
Thinking of adding 10-15mm spacers in the back to fill out the fenders a bit better.
Given the high ride height of the H&R Races, would the shorter 205/45s look odd? Too much wheel gap? Any insights appreciated. What do you think of the other two alternatives listed?
Regards,
Jay,
17x10.5. What are we looking at offset wise? I plan on rocking 235/40/17s. :D
Yes, they will be drifted on 8-)Erick Mahle | FullOpp Drift | YouTube
..::Support FullOpp::..
FullOpp Stickers for sale!
Feedback Thread
Thanks,
Jeff
Originally posted by ryno View PostPosting on behalf of a friend:
Hi Mystikal,
205/45R16
205/50R16
225/45R16
Regards,
Given the wheels, there is really not much room in the back for 10-15mm spacers and the tire choices given. A 10mm spacer and 205/45/16 tire is the most feasible option, and even then it will be close with unrolled lips. Running the 205/45 will also make the wheel gap look even bigger, as it is only a 23.2" tall tire. Your friend obviously has some choices to make here, which depend mostly on their priorities. I'd also like to note that all of the sizes he mentioned can be run on those wheels (without the spacers) without even fender rolling. For me, I'd probably buy a set of 215/45/16 Falken RT-615s, run no spacers, and enjoy the ride...but of course I'm biased. :)
