15mm, so I'll have to get studs and spacers for sure, huh ? I was also looking at the Maxxium Le Manns Mesh. They are a 35mm offset. Either way I'll need studs, correct ? Or do they sell a longer wheel "bolt" -lug.? 35mm would work with 10mm spacers, right ?
This is a sticky topic.
Spacers for sure, and yes they sell longer bolts. H&R retailers can sell you everything you need. You don't want 10mm spacers, as they will not be hubcentric (meaning...you don't want them). You can run the 15mm spacer with an ET35 wheel also.Comment
Turner Motorsports sells longer lug bolts.
I just bought a set of black ones.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
Question about my E46, help much appreciated.
I happened upon a set of MVR rims, J8.5x19 et43, any way these can fit?
-DevonLast edited by devonjordan; 05-10-2008, 04:09 PM.Comment
So if I want to run a 15x8 with a 205/50/15 wheel, what offset should I run?I got a fender roller now! LMK if you need me to roll your fenders or want to rent the tool from me locally.
Paypal: vdang5@gmail.com
Delta Auto Care
2875-C Towerview Road
Herndon, VA
703.435.1375
My Feedback Thread: Evil_TwinComment
Flush is a subjective term, show me a pic of a car with wheel fitment that you like and I can tell you how to achieve that look.Comment
Well I was going to wait and use my first post for my intro once I finished the swap on my e30, but I need to ask something.....
I have a set of BBS RM's 15x8 & 15x8.5, what size tires do you think I should go with? Or am I to limited on tire choices? I ask because I'll be doing a M50 Turbo setup, though it's not going to be heavily built or pushin' crazy amounts boost or anything like that but still.....Comment
The offset becomes really low once you widen RMs. Those 15x8s are now ET14 and the 15x8.5s are now ET8. Getting anything wider than a 205/50/15 is going to require a lot of fender work, even getting the 205 on will require a flat roll and a lot of spring rate.Well I was going to wait and use my first post for my intro once I finished the swap on my e30, but I need to ask something.....
If you want traction, I'd really suggest getting another set of rims.Comment
Just got a set of m-systems 17x8 and 17x9 in the rear. Anyway to make these fit with 235/40 17 toyo r1r's? Or should i be looking for 17x8 in the rear?
The lowest offsets for each respective size would work quite well. I'd personally get the 17x8.5 all around with 235/40/17 tires. You'd have some fender rolling to do in the back, but nothing extreme. Depending on the exact tire you may also have to run a 3mm spacer up front to clear the strut tube. This all may sound like a headache, but you will have plenty of traction afterwards. The easy way out would be the same rims but with 215/40/17 all around.Comment
