Hi all, I have a set of BBS RS 036 that are 4x114.3 and 15x7, and I believe they are et40, could I find adaptors? If so, where is a good place to look?
	This is a sticky topic.
 Well, 13mm would be perfect for obvious reasons. Since that's not exactly a common size, run 15mm spacers.
 -JayComment
 so it seems like every1 who is running 16x9's is also running undersized tires. i want to know why i cant run a 225/45/16 tire on a 16x9 et7 front, and 16x9 et10 rear? and if its not possible, what is the closest to stock that i CAN fit. THANKS!IG: @Baye30
 FRONT VALENCE IS ZENDER!!! STOP FILLING MY PM BOX PPL!!!Comment
 You can run 225/45 all around if you run an 8mm spacer. You might need to roll the fenders, but your car isn't low enough to cause horrible fitment problems.Comment
 I am running 225 45 r16 all around with 16x8 et20. You need to roll your fenders, it would probably fit better with alittle stretch.:: PNW Crew ::
 '87 325 4dr, '74 2002Comment
 One guy on here did it already. Bert or something, has a black late model with 16x9 B1's and an ACS front, super clean car. You'll need to roll the shit outta the fenders. 215/45/16 is closer to stock size and will fit easier.
 -JayComment
 You won't notice 2mm. If anything put them on the rear, because lining up spacers is easier on the hub that won't spin (keep the parking brake on).
 -JayComment
 What about for cars with 5-ug swaps? (on facelifted cars, '88+)
 I am doing the E36 M3 fronts and Z3 rears, and I am told E36 offsets are what work for wheels. Assuming this is correct (et41), I'm hoping I can run...
 215/45/R17 on a 17 x 7.5 wheel (~.5" taller than stock)
 or
 215/40/R17 (~.2" shorter than stock)
 ...without rolling . Rolling involves squishing the underside of the lip to a sharper crease or actually pushing the whole arch outward? I assume most people are just squishing the inner part of the arch flatter?
 Thanks!
 "BMW Style 32 Poster-Child"
 HTTP://WWW.CLAVINZERO.COM/e30-5-lug
 **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)**
 205/50/16 is stock diameter. Do this.
 You will need hub rings, and your stock bolts will be fine.
 -JayComment
 215/40/17 will be easier to fit. 215/45 is tall enough to cause issues with the fender lining.What about for cars with 5-ug swaps? (on facelifted cars, '88+)
 or
 Thanks!
 Rolling is just squishing the lip, yeah. No visible difference from the exterior. The factory rear arches are half-rolled, take a look and you'll see what I mean.
 -JayComment
 I see what you mean about the half rolled part.
 I was thinking that 7mm or so more towards the fender linings (from the ~15mm larger diameter) wouldn't be too bad. You think it will rub too much?
 195/65/R14 Overall Diameter: 23.98 in 609.09 mm
 215/45/R17 Overall Diameter: 24.61 in 625.09 mm
 215/40/R17 Overall Diameter: 23.77 in 603.75 mm
 I have a car on front of me with the 215/40s and the sidewall is scary small for these roads around here.
 R.I.P 07/01/09 - 04/23/10 :(
