www.discounttiredirect.com is a good source. Apparently Sears carries them in the US too, try them for a quote (get them to price match DTD probably).
	This is a sticky topic.
 ive looked through the pages in this thread and found some info on my question. however i just want to ask again to re-assure.
 im looking at buying a set of used kosei k1 in 17x7 flavor. et42mm 205/40/17 tires
 not interested in using wide tires or fender rolling.
 i've heard that these will bolt-on without spacers, is this true? car they will be mounted on is a 91 318is and is lowered on h&r sports.Comment
 INSTAGRAM: @UNDR8D_EMPIRE
 Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
 They'll bolt on, but they will sit far, far inside of the fenders. It'll also alter the steering geometry in a strange way.ive looked through the pages in this thread and found some info on my question. however i just want to ask again to re-assure.
 I'd suggest 15mm-20mm spacers. You can run those same tires and up to 215/40/17 without any rubbing.Comment
 so id like to run stretched tired on my 15x8 RM's, but I don't want them to be like this..
 I'd much rather them be like this...
 and I'd like to know what tire size to run to achieve this look...
 thanks alot.
 Originally posted by Jandersonyou can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.Comment
 I had my wheels off today and measured from the mounting surface to the shocks and from the mounting surface to the fenders on both the front and the rear.Since getting close to the fenders is a high priority, I'm going to recommend 205/40/17 tires (about the same diameter as stock on your '84) instead of 215, as it gives you more room for flush fitment.
 Run 25mm spacers with any of those rims. It will result in a final offset of 13-15, which will place the wheels nice and flush with the fenders. This will just clear with the 205 tires and not require rolling.
 They will all handle pretty similarly, don't let that be a deal breaker.
 In the front I measured to the strut itself at 133.35mm clear and then to the lower spring pad at 98.42mm clear.
 Will 17's and tires, with no spacers, be under the the lower spring pad?
 Even when slammmed with coilovers?
 Thanks for the help again...sigpic
 "Drive like you mean it. Commit."
 "Progress Fervently."Comment
 I like them, kinda look like the old 'Vette rims that some dubbers like to run.
 You'd need like 20mm spacer though. And the 195/50s that are on them will lower the car like 1 1/2" lower than a stock size tire.Need parts now? Need them cheap? steve@blunttech.com
 www.gutenparts.com
 Thanks for the info. I need to read about wheels/tires. I lack in that department and I don't like it. ;) ;)Comment
 Google the "miata tire size calculator" you can play with a bunch of different tire sizes to get an idea of the overall diameter of different tires for comparison sake. All tires will vary, but its helpful.Need parts now? Need them cheap? steve@blunttech.com
 www.gutenparts.com
