	This is a sticky topic.
 The front isn't a big deal, it's the rear that will need a lot of attention.
 The new rear setup will be 0.4" wider as well as 0.5" taller, so you'll need to push the fender out accordingly.Comment
 Keep in mind that you will need 5mm spacers to clear the front struts with those wheels, provided they are the typical ET15 versions.
 Don't bother staggering, as there is actually more room in the rear of these cars. Go with either size all around, with coilovers and rolled fenders you won't have a problem.Comment
 First, I know someone at some point found out how space IE flares actually add. IIRC it was 1.75", but you may want to verify that first before I start crunching numbers.Hey I'm getting some 16x9 Brock B1s this weekend (et 15). I will be running a bigger tire b/c I'm getting turbo flares. With the flares I want to space the rims out 10 mm up front and 17 in the rear w/ 225/45/16 KDW2s. Do you think this will clear w/ the IE flares?
 I also wanted to know what kind of caliper clearance would I have up front with this kind of spacing? I ask this b/c I want to know if the rx-7/corrado brakes will fit underneath?
 Mystikal I'd really appreciate your input, since those 17x8s didn't workout.Comment
 www.gutenparts.com
 Ok. So I've got my 16x9, need to pick a 215-40-16 tire now. I've narrowed the choices to the BFG G-Force sport or Yokohama S-Drive.
 Can you help point me in the right direction? They seem to be pretty close on paper. I've always said I'd want performance over longevity, but lately I've been thinking otherwise.. Car is daily driver, I want a tire with a good balance of traction/treadlife. Help?Comment
 HELP
 What are these wheels I have? Style 5s? What the value? The tire info is: 235-60-r16
 and a pic
  Last edited by Nicademus; 09-09-2008, 08:12 PM. Last edited by Nicademus; 09-09-2008, 08:12 PM.Comment
 I am looking into getting some axis racer x wheels. staggered. 15x7 front with normal offset. The rears is where I am going to run into issues. I am going to be using fender flares, but the size and offset are kinda of extreme. They are a 15x8 with a -27 offset. Do you think I should be good with flares and stretched tires?
 rear wheel pic:
 I am tempted to get a set of 501's in 16x8 for winter use and put some all seasons on them. But I dont really see 225/50s on an early car having an issue fitment wise. By going with a larger tire does that make the speedo slower or faster?Last edited by nefarious7907; 09-11-2008, 09:28 PM.Comment
