basketweaves!!!!
  • threlevenguy
    • Dec 2006
    • 1057
    basketweaves!!!!
    anyone know how wide of a tire i can get on the stock "iS" 15" basketweaves
    • 34839
    how wide are you thinking? a 225 would be easy. I have 225 hoosiers on the 14" weaves which are only 6.5" wide. 15" weaves are 7"
    • euroshark
      • Apr 2006
      • 3491
      You might be able to fit a 245/45/15 Hoosier or Kumho, but that's stretching it... You'd have to have a bad ass tire guy to get it to work considering that they are track tires... I don't know of any street tires wider than a 225/50 that are the right diameter.
      • Mystikal
        Wheel Fitment Expert
        • 9602
        Anything wider than a 225 for a street tire will handle terribly.
        • threlevenguy
          • Dec 2006
          • 1057
          my bad i have 195/65/14s....think i could get a 215/45/14 ?
          • e30_325es
            • 1249
            Do you have any rubbing problems?
              • 34839
              no, thanks to a sledgehammer and a dremel for the rear fender flares ;)
              it's *really* close though..
                • 34839
                215/45-14? do they even make that size? even if they did, I can't imagine many of them being great tires.
                there are a few decent choices in 205/60-14. the Falken 512s for example.. but if you want a high performance tire, you'd be better off with the Azenis RT615 in 195/60, or the Hankook RS2 in the same size. width isn't everything..
                • Mystikal
                  • 9602
                  Yeah...and those wheels are only 6.5" wide too. Run either of the 195/60/14 tires nando mentioned.
                    • 37829
                    Don't bother going bigger than 205/60 on that wheel.
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
