Just put 80mm studs on (pics)
    • 34839
    Originally posted by joshh
    Brand new set of what? Studs? From the same manufacturer of the studs that BigD is using?
    I realise that but the thickness of the wheel will determine how many threads go into the hub. The bottlecaps and the stock bolts have about 1" of threads that go into the hub.
    Even the SCCA requires 8 threads.
    I'm sure it will be fine....I hope.;) If BigD isn't worried about it, then I have no reason to worry for him.
    you are very, very confused. the hub isn't even 1" thick.. so I don't know how you'd get 1" of threads into it. and the wheel has nothing to do with how many threads go into the hub (with studs, anyway).
    I just ordered a set.. I don't need the really long ones, but you can't beat $50 for a whole set at the stock length. I'm looking forward to changing wheels every weekend now :D
    • joshh
      • Aug 2004
      • 6195
      Confused, no. I never said the hub was 1" thick but I did expect it to be more than 6-7 threads deep...which it is, now that I had a chance to look.
      And the wheel has everything to do with how many threads go into the hub. Different wheels have different thicknesses from the bolt mounting areaon the wheel to the hub mounting surface. Obviously this doesn't apply to studs.
      "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
      ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
      • Van Westervelt
        • 9365
        I am not even going to continue this conversation.
        • Rocla
          • 922
          If the inner threaded part of the stud would be an inch long, it would most likely hit the e-brake mechanism(or the actual brake mechanism with drum brake e30's), whichwould be disasterous.
          Current:
          BMW 320i 2d 2.0 m20 -88
          BMW 325i Cabriolet 2.5 m50 -88
          BMW 316i touring 1.6 m40 -90
          BMW 320i 4d 2,2 m54 -01
            • 34839
            uhm, way to basically restate what I already said. you were confused...
            • george graves
              • 20003
              Is it posiable to damage the paint in the wheel holes if you get careless putting a rim on?
              Originally posted by Matt-B
              • backtrail69
                • Jul 2005
                • 4471
                It is just like putting a wheel on any car with studs...
                :: PNW Crew ::
                '87 325 4dr, '74 2002
                • george graves
                  • 20003
                  I bet it is - but my knowledge is limited to bimmers, so that doesn't really answer the question for me (sorry)
                  • backtrail69
                    • Jul 2005
                    • 4471
                    Well you just line up the wheel with the studs and put it on, instead of setting it on the hubcentric lip. Its way easier. You shouldn't damage anything unless you are very careless. BMW used to use studs... my 2002 has them. :P
                    :: PNW Crew ::
                    • george graves
                      • 20003
                      Thanks for the reply backtrail.
                      I was just looking at the 80mm of threads and thinking they were ready to eat some paint.
                      • joshh
                        • Aug 2004
                        • 6195
                        Um no, :finger:
                        Well obviously it doesn't because that is how long the bolts stick out the back of the stock bottlecaps.
                        • Mastrcruse
                          • Sep 2005
                          • 5340
                          so any one know if anyone sells theft deterent lugs?
                          • Van Westervelt
                            • 9365
                            I am planning on buying some soon. www.toxicrides.com has a set of lightweight black locks. They did a spotlight on them in p. bmw.
                            • Van Westervelt
                              • 9365
                              Um no, :finger:
                              :loco:
                              • Mastrcruse
                                • Sep 2005
                                • 5340
                                What section is it under? I went through them and didn't see any, sorry if I am completely blind.
