Wheels are Finished
  • modifiede30
    • 1208
    Wheels are Finished
    Finally finished the wheels. Utter PIA to clean all the brake dust off. Ended up removing a bit of the clear coat but they turned out okay.
    Before:
    After:
    Driving is the only way to go faster....
  • bwanac
    • 3354
    Very nice! :up:
    I plan on doing that route once I find my wheels.
    • OOMPH!
      • 3487
      the wheels look great......much better than before!
      • Jordan
        • 12916
        eh
        https://mtechniqueabs.com/
        • modifiede30
          • 1208
          eh
          Better than your first response when you saw my car so I guess its an improvement.
          • EtaSport
            • 2853
            That doesnt look too bad.. Spray some tire shine on those tires though. Did you use anything on the lips to polish? I had to completely strip mine because brake dust have caked on and I had to wetsand the entire lip.. I never really could get it to polish nicely and when i clear coated it, that was the end.
            What size tires are you running? look similar to mine
            Old and improved:
            • modifiede30
              • 1208
              That's about what happened to me. The lip isn't that bad, but I couldn't get the finish to be consistent. The tires are 205/50/15's. I think the car will look better when the racing colors go on (obviously black). Not sure what I'm going to do yet but I suspect black markings on the hood and sides, with white lettering.
              • ToplessE30
                • 4791
                Looks better IMO. :up:
                Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
                • Digitalwave
                  is a poseur
                  • 6300
                  I looks good! What paint did you use, got any tips to offer?
                  RISING EDGE
                  • modifiede30
                    • 1208
                    VHT paints were used. I've had good experiences with these before but mainly on engine components. If you're going to keep anything polished metal, make sure that you remove all of the clear coat, or leave it all. Don't remove some and leave some in other places or you'll get a pretty spotty look. Also, use fine sandpaper where ever you're going to paint and make sure everything is clean. I used indoor masking tape made for painting trim work. This worked great when it came to masking off the lip. Let them dry overnight before doing anything. Its also best to make sure that the undercoat isn't tacky before appyling the clear coat. Multiple coats works much better than one heavy coat.
                    • kencopperwheat
                      King of Kegstands
                      • 14396
                      I think they look pretty damn good. I like those wheels painted black better than the silver.
                      Originally posted by Gruelius
                      • gds318is
                        • Mar 2004
                        • 33
                        Yeah..Looks nice 8) :idea:
                        • Jand3rson
                          • 37587
                          I think they looked better before.
                          • Fuddy
                            • 123
                            before > after
                            • rscheiring
                              • Jan 2004
                              • 1014
                              Nice Dan. What wheels are those?
                              A great pleasure in life is doing what people say you cannot do- Walter Gagehot
