BBS RS question
    BBS RS question
    Is there anyway to prevent some low life from stealing the centercaps?
    Loctite?
    Threadlocker? I doubt that would deter a thief I'd take them with you or lock them in your trunk.
      find a way to safety wire the things on. hehehe.
      -Chris
        this is the reason i don't put on my center caps. i also like the look without the caps
        1991 330is
          You can use a small drill bit, drill through the cap, then into the wheel and screw them on.
          Just a little project im working on
          - http://www.lse30.com -
            Loctite might deter a casual theif but maybe not a determined one.
            Is there no solution other than to remove the caps everytime I park the car? This is worrying!
              Retrofit combination locks into your center caps!
                Proximity alarm FTW .
