newbe rim question
  • flagger123
    • Oct 2007
    • 9
    newbe rim question
    i just got my first e30 a few weeks ago its a 87' 325i and i love it so far. I want to put new rims on it and i had borbet LS in mind. they are a 15x6.5 with a 38mm offset. they take a 195-50-15 tire. Now im new to e30's and idk if they will fit. i called tirerack.com and they said that it wouldn't fit and he said if i used a spacer it would hit the wheel well. i bav auto springs on my car so its droped about 1.6 inches. i just don't wanna buy like $1,000 worth of rims and tires and have them not fit. any advice would be great.
    thanks
    Rob
  • Jordan
    • 12913
    Borbet LS is a pretty ugly wheel IMO.
    Now that aside.. yes those will fit fine.
    You should use a 15mm spacer, and run a proper sized tire. 195/50R15 is very undersized. Either run 195/60R15 or 205/55R15
    https://mtechniqueabs.com/
    • flagger123
      • Oct 2007
      • 9
      Where is a good place to get spacers? what kind of spacers do i need i think their is different kinds....
      • Jordan
        • 12913
        Turner Motorsport has a good selection of H&R spacers.
        You did not mention what the center bore is on that wheel and I wasn't able to find the info after a google search.. but that plays a roll too.
        • flagger123
          • Oct 2007
          • 9
          this is going to sound really week but i have no idea what the center bore is...
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            The "circle" in the center of the wheel. Think hub seating region.
              • 37829
              You may need to buy the spacers and also some hubcentric rings.
              The best place I have found for hubcentric rings is www.discounttiredirect.com just give them a call and tell them what you need.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • flagger123
                • Oct 2007
                • 9
                what would be the biggest offset i could put on the car before i would have to get spacers? cause i also was looking at Kazera KZ-M's and they only have a 25mm offset. would i still need spacers?
                • Jordan
                  • 12913
                  Not enough information provided.
                  Width, diameter, planned tire size.
                  • flagger123
                    • Oct 2007
                    • 9
                    o sry... they are 15x7 with a 25mm offset and they recommend a 205/55-15 size tire
                    • Mystikal
                      Wheel Fitment Expert
                      • 9602
                      That's a perfect fitment.
                      Jay
                      • AndrewBird
                        The Mad Scientist
                        • 11898
                        I believe with a 7" wide wheel, 25mm is BMW factory offset. Someone correct me if I am wrong.
                        • Mystikal
                          • 9602
                          24mm is.
                          Jay
                          • flagger123
                            • Oct 2007
                            • 9
                            awesome thanks for the help
                            • m20e30
                              • Sep 2007
                              • 10
                              check these out and look no further. 17x7 w/20mm offset. Direct fit, no worries;
