i got the set on this site, and they just hit the front caliper with a 3mm spacer they clear but are out side the fender a little. have bavauto springs and billy sports. i think i'm going to get 195 55 15's think ill have problems with the front rubbing? and i have hub centric rings with the rims will i just get a universal spacer or will it need to be hub centric on it? pics later tonight.
					dr20 15x7 need some spacer help.
 dr20 15x7 need some spacer help.Last edited by 1991 e30 bmw 318is; 03-04-2008, 04:41 PM.91 e30 318is M50 SOLD
 http://www.r3vlimited.com/board/showthread.php?t=149570
 92 325 vert project
 http://www.r3vlimited.com/board/showthread.php?t=341370Tags: None
 I got the same ones, and he said they cleared the caliper. I have not put mine on the car yet cause the lugs was not sent with my order. But i did just go out and flop them on there with out the lugs and held it tight, and it looks like it does clear on mine though.Last edited by JasonC; 03-04-2008, 01:43 PM.
 1992 BMW 325iC
 1978 Chevrolet Monte Carlo1965 Chevrolet Corvair Monza 140hp
 ya mine looked like it did tell it was snugged up. and the bolts are too long. they hit the dust shield on the disc, and that was with a 3mm spacer. are your pads old or newer? if you put new ones in it might hit your rims.91 e30 318is M50 SOLD
 92 325 vert project
 http://www.r3vlimited.com/board/showthread.php?t=341370Comment
 got the bolts today there to long, but i can cut them. managed to get the stock one on thew front and the new ones on the back. just sat it down on some pads to see whats going on. cars kinda lopsided but you get the idea. no spacer on the back. 3mm on the front with the hub ring in it. if i get 3mm spacers should they have the hub centric ring on them? or just use the ones that came with the rims?
 this shows where i was grinding to make room, but might not need to now with the spacer.
  91 e30 318is M50 SOLD 91 e30 318is M50 SOLD
 92 325 vert project
 with the 3mm spacer and the caliper grinded it clears but with out grinding it wont clear. its out side the fender a little not sure if ill need to roll fenders? and the back is flush. with no spacer. just need to know if i need to use hubcentric rings with the 3mm spacer or get a 3mm spacer with hubcentric rings built on them.91 e30 318is M50 SOLD
 92 325 vert project
 92 325 vert project
 just went to a shop that does laser cutting and told them about what i want so there getting a quote on laser cut spacers. might get a few made and sell and them. i think ill make them hub centric to the e30 hub then put the spacer on, then the hub centric rings that came with the rims. then will i need to roll fenders? i think i will.....91 e30 318is M50 SOLD
 92 325 vert project
 so you have no spacers? dam that looks bomb. whats the tire specs? were your front bolts to long? and will you need to roll the rears? or just the front?91 e30 318is M50 SOLD
 92 325 vert project
 The tires are 195/55 Falken Ziex ZE-512. No spacers, i just ground on the caliper. The lugs i didn't get from him (since they never showed up), i found some else where. The front it's really tight so i'd roll them to be safe. The rear i can fit my fingers between the tire and 1/4 lip.
 1992 BMW 325iC
 1978 Chevrolet Monte Carlo1965 Chevrolet Corvair Monza 140hpComment
 thats bomb! i think i an getting the same tires, i can get them $420canadian out the door on the rims. i rolled the little edge on the front of my fender on one side (didn't get to the other side yet) so it wont catch it not sure if its enough well see soon!91 e30 318is M50 SOLD
 92 325 vert project
