wheel spacers
  • brn2ply7
    • 301
    wheel spacers
    These vdub spacers will work on an e30 correct?
    http://www.ecstuning.com/stage/edpd/...heel%20Spacers
    89 325i parts car
    90 325i in progress
    ground control 400f 700r-koni adjustables-koni adjustable sways-reinforced control arms-ground control camber plates-e36 cabrio shock mounts-4.10 lsd-5 speed swap in the works
    --tryng to join the schwarz army one day at a time--sigpic
  • MG325i
    • Jan 2007
    • 805
    i dont see why not. it looks like they'd fit just fine.
    E30 325I > SOLD
    E30 318IS > SOLD
    E39 530I > SOLD
    EP3 > SOLD
    95 M3 > SOLD
    97 M3 > DD
    • cbouchez
      • May 2007
      • 2789
      yes they should same hub size 57.1
      Follow my IG @bouchezphotography
      • cheades
        • 632
        I have a set of the 12.5mm and they fit great.
        • EN318isPDX
          • Oct 2007
          • 4373
          wheel spacer = bad
          • z31maniac
            • 17566
            Originally posted by EN318isPDX
            wheel spacer = bad
            www.gutenparts.com
            • brn2ply7
              • 301
              HAHA ok just makn shure gents. no need to start this wheel spacer thing for the umteenth time. Thanks
              89 325i parts car
              90 325i in progress
              • Mystikal
                Wheel Fitment Expert
                • 9602
                Are they actually 57/57.1mm hubcentric on both ends?
                This could be interesting.
                • cheades
                  • 632
                  Yes, they are made for VW's which have the exact same hub bore as the e30.
                  • Mystikal
                    • 9602
                    Well then.
                    I'm curious if their 10mm ones actually really are hubcentric. That would make these the thinnest real hubcentric spacers for our cars.
                    • Van Westervelt
                      • 9365
                      wheel spacer = bad
                      :tsk: Wrong. Stop spreading misinformation like a tire jockey at Americas Tire.
                      • kamotors
                        • Nov 2007
                        • 7102
                        wheel spacer=cool.
                        i've been running H&R spacers for months, and haven't even noticed the slightest vibrations with them.
                        its the only way to make bottle caps look good.
                        7speedshop.com
                        • EN318isPDX
                          • Oct 2007
                          • 4373
                          i am no tire jockeys but i know how physics work and extending a wheel hub out it puts extra pressure on the wheel bearing thus will cause it to prematurely fail
                          • whiltebeitel
                            • Apr 2007
                            • 2098
                            the change in offset of the average wheel spacers (20mm or less) is insignificant compared to the driving conditions the wheel bearing are designed to withstand. That's like saying you're seat is going to break since you gained a few lbs.
                            '89 325i track sloot
                            '01 530i daily
                            -Enginerd
                            • e30rcr
                              • 383
                              So will more weight from anything but a 14" x 5.5" wheel, but who the hell keeps Bcaps.
                              If by prematurely you mean it will shave a week off of it's working life, then I agree.
