Which Wheel To Get?
  • Tbolt
    • Nov 2007
    • 1165
    i went with are you serious? but I am curious as to what they would look like on an e30...so be my guest =D
    Tbolt Division
    All I'm saying dude is that bird law in this country...it's not governed by reason.
    • rThor432
      • Feb 2007
      • 3907
      Originally posted by OrganicMechanic
      16x8 225/50/16 frnt
      17x9 245/45/17 rear or 16x8 245/50/16 rear
      That's a lot of sidewall.
      I cant help you with wheel choices, sounds like you are pretty set on the Hummer reps.
      • OrganicMechanic
        • Jan 2008
        • 1719
        I like a little side wall. I run a 205/50/15 right now so I think it would be close to the same road feel just more connected. Therory at least.
        I do have a request in to get them P-choped so...
        join the E30 Cabrio owners gruppe
        click here for details
          • 34844
          you have no idea how sidewall works do you?
          a 205/50 has a 102.5mm sidewall height. a 245/50 has a 122.5mm sidewall height. that will not only look totally fucking stupid, it's going to be really ugly with those horrible wheels you found.
          I don't believe those out of thousands of wheels available those are the only ones you could find. I still think you're trolling.
          • OrganicMechanic
            • Jan 2008
            • 1719
            Why are you
            so hostile
            over something
            I
            want to do or not
            with my car?
            And to be honest--I don`t understand what you mean by trolling.
            your math is off---
            45% of 245mm =110mm
            50% of 205mm=102.5mm
            difference of 7.5mm
            10mm=1cm
            10mm=1cm>7.5mm
            • atomic
              • Jun 2007
              • 5691
              Choice 1--click here
              Choice 2--click here #2
                • 34844
                Why are you
                so hostile
                over something
                I
                want to do or not
                with my car?
                your math is off---
                45% of 245mm =110mm
                difference of 7.5mm
                10mm=1cm
                10mm=1cm>7.5mm
                your reading is off
                those wheels look like they belong on a fucking donk
                • z31maniac
                  • 17566
                  ones that fill MY requirments seem to be.
                  You aren't looking hard enough if the best you could come up with is some shitty truck wheels.
                  You obviously have no idea about what O.D. tires will fit on an E30. So you are going to flare the fenders out to fit tall sidewall tires on shitty truck wheels, you are fucking awesome.
                  It doesn't really matter though, I suspect that you won't even get the 5 lug swap done.
                  www.gutenparts.com
                  • OrganicMechanic
                    • Jan 2008
                    • 1719
                    Originally posted by what I wrote
                    16x8 225/50/16 frnt
                    17x9 245/45/17 rear
                    or
                    16x8 245/50/16 rear
                    50% of 245=122.5mm
                    102.5mm from 122.5mm is 20mm==
                    20mm x .03937=.7874inches
                    rounded to 3/4 of an inch sidewall difference
                    reallly??
                    it really is hard to accept?
                    • OrganicMechanic
                      • Jan 2008
                      • 1719
                      parts in basement--just need to reinvest in new equipment to complete
                      • z31maniac
                        • 17566
                        Then add another half inch since you're going from a 15 to a 16.
                        Fuck, you're dense.
                        www.gutenparts.com
                        • stormspike
                          • 401
                          I like these new wheels I just put on!
                          • OrganicMechanic
                            • Jan 2008
                            • 1719
                            no, your again misunderstanding data set.
                            Fuck, you're dense.
                            yes you are
                            • OrganicMechanic
                              • Jan 2008
                              • 1719
                              I like the Throwing stars--but they are a +42mm offset if I am recalling correctly
                                • 34844
                                245/50-16 is 1.7" too tall
                                245/45-17 is 1.8" too tall
                                I don't think he's misunderstanding anything
