Offset for stupidly wide wheels?
  • radback
    • Apr 2004
    • 37
    Originally posted by E30_boy
    I had KW V2's on my Jetta, I wanted to get a set for the Bimmer but my KW dealer here says there is no listing for E30 :? Also did they make RS's 4x100 in 16"? I'v only seen 15" RS' in 4x100
    KW Variant2 exist for E30. They cost around 1000 euro in germany
    Motorsport Edition Convertible
    • qimis
      • Mar 2004
      • 279
      yes they do. i have KW V1 in my car. tunershop.com carries them, you have to special order for that. they also have KW V2 as well for around $1,600 if i'm not mistaken.
      • Brew
        • 3060
        Is the KW a true coil-over system in the rear?
        '91 318is
        • E30_boy
          • 226
          I can get the H&R coilovers for 1,900 CDN with tax. I hear H&R's are even better then the KW's
          • Mystikal
            Wheel Fitment Expert
            • 9602
            That's a damn good deal. Are you considering them?
            • qimis
              • Mar 2004
              • 279
              but i think w/ H&R only the front that's adjustable, the rear isn't. if i'm not mistaken.
              • E30_boy
                • 226
                Ok so I am building up a custom set of Corrado steelies in 15". The fronts will be 15x8 and the rears will be 15x9 with a nice lip. I can get the offset changed to whatever I would like. What would work best on my E30? The Corrado steelies are ET35 right now
                Thanks
                -Jordan 8)
                PS. The H&Rs are fully adjustable front and rear ;)
                • Madhatter
                  • Oct 2004
                  • 966
                  Just measure the backspace and compare it to any wheel you want to fit. As long as you leave a good 15-20mm of clearence you shouldnt get into any trouble at all. You can pretty much just ignore the offset if you get the backspace correct.
                  Just a little project im working on
                  - http://www.lse30.com -
                  • royalflush313
                    • Mar 2004
                    • 2070
                    16x9 wheels, et15, w/ 215/40/16s (i know, its undersized and it will be stretched).
                    - On a 318iS with H&R sports springs
                    would this set fit w/o fender mods, what if i went 225s? et15 low enough, or will I still need spacers?
                    Thanks.
                    ~ Go Canucks Go! ~
                    • ragehardintothebendies
                      • 50
                      for 16x9's with a 215/40, I beleave you need et7.
                      www.islandmma.com
                      • qimis
                        • Mar 2004
                        • 279
                        ^^^ ET 5 maybe ? AndreNY had ET 5 on his old Borbet A
                        • -e30-
                          • Jul 2011
                          • 1
                          Originally posted by 808BMW
                          What offset is needed to have a 10" wide wheel up front with no (or as little possible) rubbing. Only the inside matters, fender clearance is not an issue.
                          How about 12" out back? again, inside only, fenders don't matter.
                          10 -12 front
                          12 -12 rear
                          will clear strut and inner fender.. would need much wider fenders.
                          • Stephen
                            Шлем ишака
                            • 10774
                            im sure its been sorted by now
                            • B-well
                              • 1042
                              10"+0 is the highest offset you can run for 10s in the front
                              i have 9.5+8 in the front of mine and have about 3-5mm of clearance and 10+0 will be the same inner specs
                              as for the rears
                              i ran 10+22 in the rear with 5-6mm clearance
                              you can run 12"-4 with the same clearance
                              you will be 2-2.25" ouside the rear fenders
                              • B-well
                                • 1042
                                lol 7 years i hope he got it covered
