Offset for stupidly wide wheels?
  • 808BMW
    • 2910
    What offset is needed to have a 10" wide wheel up front with no (or as little possible) rubbing. Only the inside matters, fender clearance is not an issue.
    How about 12" out back? again, inside only, fenders don't matter.
  • kylebes1
    • May 2004
    • 2804
    you plan on steering with those 10" wheels in front?
    • M-technik-3
      • 18946
      8" maybe with varying degrees of fitment. 10" I just don't seeing it happening.
      • Ryan Stewart
        I Love Miatas
        • 8978
        It would have to be super low, like 5. That is if fender clearance was a non issue, youd need one hell of a widebody.
        Dunno about the 12" though, my 8" run pretty dam close in et28
        Im now E30less.
        • qimis
          • Mar 2004
          • 279
          i was driving around for a day until i noticed that the guy putted my 10x16 at the front and 9.5x16 at the back only on one side. :nice:
          • M-technik-3
            • 18946
            What kind of shop did that? I won't let shops touch my BBS. I do them myself, ie Mounting and Balancing.
            • 808BMW
              • 2910
              Rubbing with 10's up front? What's the offset on your RS's anyway?
              • royalflush313
                • Mar 2004
                • 2070
                wow..
                What offset are you running, and what size adapters are you using? 25mm?
                ~ Go Canucks Go! ~
                • qimis
                  • Mar 2004
                  • 279
                  it was a body shop where i got my car from and installed the mtech 2 kit. hehe lucky you ... you can balanced it your own.
                  didn't rub, i had the front just less than 1" gap b/w fender and tire. probably it will rub if it's lower than that.
                  wow..
                  front: ET 5, w/ 25 mm adapters
                  rear: ET 3, w/ 20 mm adapters
                  • Digitalwave
                    is a poseur
                    • 6293
                    wow..
                    So you the rims in the front are ET30, with 25 mm spacers, or are they effectively ET -20mm?
                    RISING EDGE
                    • Mystikal
                      Wheel Fitment Expert
                      • 9602
                      • qimis
                        • Mar 2004
                        • 279
                        nope, there's more complicated calculation behind it. those offset that i posted are final offsets.
                        • royalflush313
                          • Mar 2004
                          • 2070
                          ^^ Qimis, what kinda suspension are you running, and your fenders modded?
                          ~ Go Canucks Go! ~
                          • qimis
                            • Mar 2004
                            • 279
                            i'm running on KW Variant 1.
                            fenders were rolled to the max. :mrgreen:
                            • E30_boy
                              • 226
                              I had KW V2's on my Jetta, I wanted to get a set for the Bimmer but my KW dealer here says there is no listing for E30 :? Also did they make RS's 4x100 in 16"? I'v only seen 15" RS' in 4x100
