Wheel and tire fitment question
  • SEdgell
    • Jan 2008
    • 348
    What's the largest wheel and tire combo that can be installed on a non m car, and I mean width not so much wheel diameter. I'm thinking of going with some 15x8s, can you run 225s or larger without any clearance issues? What offset, if any, wouldn't require spacers? And what size lug bolts would be needed with that wheel/spacer size?
    • 34839
    you can fit a 235 r-comp on 15x8s with rolled fenders.. specifically the Toyo R888. has to have the right offset though.
    may be possible to fit a 245 but there aren't very many 245s that are close to the same rolling diameter of stock E30 tires.
    • SEdgell
      • Jan 2008
      • 348
      What offset would be needed to fit these without them sticking out beyond the fenders, and would spacers be required? Also would I encounter any rubbing?
