Touring Strut Housing Size
  • markpopaj
    • Dec 2013
    • 131
    Just picked up my 1989 318i touring last week and started to change the struts on it for some Konis. I read on the forums that the late model E30s were equipped with the larger strut housing, but when the 51mm strut was definitely not sliding into the strut housing once I had it off the car. Ended up just putting the springs up front, and now I'm trying to exchange the struts.
    Can anybody else confirm that the tourings have a smaller strut housing?
  • cory58
    • 1021
    I believe it's 4 cyl vs. 6 cyl, not touring vs. other E30. Check RealOEM. I think you will see that tourings with M20 engines have the same (larger) strut housings as USA cars. The 4 cyl tourings have smaller struts.
    Cory
    1992 325i Cabrio
    1988 320i Touring
    2000 M5
    1977 530i
    2015 328i - Euro Delivery/Performance Center Delivery
    BMWCCA
    E30CCA
    • roguetoaster
      Biggus Tippus
      • 7830
      Before Sept 89 production 318i models have the 45mm strut housing, which is annoying. Technically, it is a late model, but BMW decided to put the smaller struts (which only came on M10 E30s in the US) on M40 powered tourings. All other tourings got the 51mm struts.
