Motor Mounts
  • cory58
    • 1021
    Motor Mounts
    I just looked up the motor mount part number for my touring on RealOEM and it's different than the part for USA E30s.
    Part # for my touring: 11811132321
    Part # for USA models: 11811132323
    It looks like the 321 part number came on euro M20 models (320 and 325 sedan, coupe, cabrio, touring), and the 323 part number came on USA and some euro models.
    Does anyone know if there is a difference in the parts or why different parts were needed? The 323 part is readily available (OE and OEM), so the more important question is can I use that part on my touring?
    Thanks, Cory
    1992 325i Cabrio
    1988 320i Touring
    2000 M5
    1977 530i
    2015 328i - Euro Delivery/Performance Center Delivery
    BMWCCA
    E30CCA
  • roguetoaster
    Biggus Tippus
    • 7830
    Any of the motor mounts should work just fine. Pretty sure it was a spec difference in durometer for the softer N. American market.
    • cory58
      • 1021
      Member "uturn" was nice enough to PM me with the following info, so thought I'd share it with everyone.
      "May have something to do with the engine mounting brackets. Your touring has aluminum arms where the #2323 is associated with the steel arms. Looking at pictures of the mounts, the stud is longer on the #2321 which I would assume is because your aluminum arm is thicker."
      1992 325i Cabrio
      1988 320i Touring
      2000 M5
      1977 530i
      BMWCCA
      E30CCA
      • roguetoaster
        Biggus Tippus
        • 7830
        Forgot about that, good reminder.
