e30 Touring door trim (unique?)
  • p0w3r
    • Mar 2021
    • 2
    Hello everyone and greetings from Moscow!
    I've recently became a touring owner, but already having a hard time trying to find some spare parts that are missing.
    So the main question is concerning the door trim. Are those elements the same as for sedan? Because it seems that the bottom pieces of rear doors should be the same length for both.
    Also, wanted to ask the same question regarding the trim right below the window.
    Click image for larger version  Name:	7IZdmFvqRt8.jpg?size=432x475&quality=96&sign=019beea318be1d02e11d88cd2ecd9d0f&type=album.jpg Views:	0 Size:	43.3 KB ID:	9979130
    Thanks in advance for your reply!
  • roguetoaster
    Biggus Tippus
    • 7818
    I think they are the same, but you can check the interchange/use on bmwfans, realoem, or other similar site.
    • 323i E30
      • Dec 2017
      • 45
      Greetings!
      The lower part of the rear doors appears to be the same, so I suppose it should fit: https://www.e30zone.net/e30wiki/index.php?title=Doors
      Best double check it though, as already mentioned.
      • brutus
        • Dec 2016
        • 593
        hi,
        YES .
        touring doors have the those same trims as a sedan
        its the windows that are different,,
        i have many e30 sedan & touring parts available,
