Figured I might as well post all this here since we now have a 5er sub-section and Otis mentioned something to me a while back. I subsequently sold my e30 last november and miss it very much. But I replaced it with a 95 M3 which is fun. But here is my 1993 "525i." Currently has S50 cams and TRM type turbo setup.
I have had it for close to 7 years and have done a TON of work on it. Especially recently. It is almost perfect for me, but there is always stuff to do. On tap is to redo the downpipe. A built 3.0L bottom end for the motor in 2013. Eventually a paint job and refinishing the wheels, maybe a set of new ones too. Then redoing the headliner and interior bits in alcantara. And I am constantly making changes to the stereo system. I compete with it in MECA and am on Team Hybrid Audio Technologies so I am constantly changing things slightly.
But anyways here is some good stuff :) Sorry for the quality of some of the pics. All of this was cut and pasted from my BF.c threads so I am including a lot of process pics and not just final stuff.
Turbo stuff:
The Turbo setup:
Essentially TRM Stage 1.5
blow through TRM tune with MAF & 60lb injectors
Biagio/SPA 7000H turbo
Otis top mount manifold
Tial 38mm MV-S wastegate
Hyperboost diverter valve
Motor prep etc:
ARP 2000 studs
Cometic MLS .140 HG
Stewart High flow water pump
aluminum thermostat housing
80c thermostat
NGK BKR7E sparks
16 inch Mishimoto slim pusher fan (1900cfm)
17 inch CCI-1730 2 5/8 inch puller fan and shroud (2700cfm)
TRM water temp sensor flange
Southbend Stage 3 clutch and flywheel
F1 14lb. flywheel
Piping exhaust etc:
ebay intercooler 24"x11"x2.5" core
AEM Dry flow 9"x4" canister/cone filter
custom CCV evac setup
3 inch exhaust
Vibrant Ultra Quiet Resonator
Dynamax VT muffler
Gauges and logging:
Parker Performance e34 shift surround with gauge panel
Rally Road steering column gauge pod mount
AMS-500 digital boost controller
Defi Red Racer Boost gauge
AEM digital water temp gauge and sensor
Zeitronic ZT-2 wideband and datalogger & ZR-2 multi-gauge.
Defi Red Racer oil pressure gauge
AEM digital oil temperature gauge
Turbo stuff:
The Turbo setup:
Motor prep etc:
ARP 2000 studs
Cometic MLS .140 HG
80c thermostat
NGK BKR7E sparks
F1 14lb. flywheel
Piping exhaust etc:
3 inch exhaust
Dynamax VT muffler
Gauges and logging:
