Swap Suggestions
  • AsharC
    • Jun 2011
    • 1508
    Swap Suggestions
    Hey all,
    I found out that my e28 motor was seized. Now I am looking for a new motor. I am taking suggestion on what I should swap into it. I am willing to fabricate.
    I am thinking about m60's and m62's.
    Let me know what is possible.
    Thanks
    BUY MY WHEELS! BBS E50s!!
    http://www.r3vlimited.com/board/showthread.php?t=275407
    Originally posted by Lurker27
    Any man will tell you being blown is better than being stroked.
  • slammin.e28
    שמע ישראל
    • 12054
    M60/2s are great. Most straight forward is the B35 though.
    I've got a friend who's doing an M70.
    How deep do you want to go?
    • iamsam
      • Jun 2008
      • 174
      don't be fooled, slammin can take it deeper than you think he can. Looks are deceiving.
      Also, i second the M60. Cheap, powerful, light, plentiful. The only downside is the amount of fab work that needs to be done.
      I have also seen people put in M50s, S50s, etc although I don't see the point. Also, like slammin said, M30B35 is the easiest way to power.
      • AsharC
        • Jun 2011
        • 1508
        I think I might go with the b35. I want the power of the M60 but not al the fabrication lol. I need the car as soon as I can get it running.
        What would I have to do to swap in the motor?
        • iamsam
          • Jun 2008
          • 174
          Read the comprehensive B35 swap thread on mye28.com.
          • AsharC
            • Jun 2011
            • 1508
            I hit the search button right after I posted.
            • slammin.e28
              שמע ישראל
              • 12054
              Best, most optimal thing you can do is get a B35 with wiring harness and ECU from a 1987+ e24.
              I got my B35 from a previously swapped B35 car that had rusted out.
              Lemme tell you, B35 with a M5 flywheel and clutch, 3.25 LSD....makes for a rather fun ride!
              I've got a 3.73 in waiting for after the Vintage....
              • slammin.e28
                שמע ישראל
                • 12054
                Also, the earleir your B35 the better. Something with cylinder bores, coolant shit and what not. Search around on Mye28, there's a particular reason the early B35s are better. Can't think of it off hand.
                • iamsam
                  • Jun 2008
                  • 174
                  and then:
                  • AsharC
                    • Jun 2011
                    • 1508
                    I already have a 3.73 LSD, and I have a Spec stage 3 clutch, so I need the motor lol
                    • B83M533W
                      • 99
                      I have a fresh b35 block, cleaned and measured. Pistons also cleaned and checked. b35 head decked and taken apart for a new cam and rockers. I also have a lot of the support items, starter, alternator, power steering pump, harmonic balancer, intake and exhaust manifolds, and other little bits. Let me know if your interested.
                      1983 533i - in the middle of a m30b35 swap
                      1986 528e - the DD
                      1992 325i Vert
                      • AsharC
                        • Jun 2011
                        • 1508
                        Pm'd
                        • AsharC
                          • Jun 2011
                          • 1508
                          i am dropping in a b34. The previous motor was a b32 out of a 633csi. I had a question about needing an harness or not? Would I need the harness and the ecu from another e28?
                          The car has the factory harness for a b34 and the same ecu.
                          • russhixmo
                            • Jun 2011
                            • 336
                            I'm in the same predicament as you rite mow (actually just started a thread about it 10 min ago). I wanna go big though, I love torque so I wanted to go s54 or m62 but I can't decide!!!
                            • AsharC
                              • Jun 2011
                              • 1508
                              Trust me, I was in the same boat. Everyone wants me to go big, but I do not have time and the $$ for fabrication and all the stuff. I went with another m30, they are pretty torquey.
