j
Removing kidneys and grilles?
look at the front of the car and find the screws that screw the grills in. i think on the e30 theres only like 3. the kidneys should just be a few metal clips. its literally that simple.Past: 1987 325iS, Bilsteins - HR Sports
Present: 1999 M3, Koni Yellows - HR Sports - GC Camber Plates - UUC Swaybars - UUC SSK - AFE Intake - Stromung Catback
2009 Mazdaspeed3, Short Ram Intake - Turbo Inlet Pipe - 2nd cat Delete - Catback - Fuel Pump Internals - Cobb Accessport - Stratified E30 tune - 294/342 - SPC Camber Arms - CPE Rear Motor Mount
I don't think you can get the headlight brackets free without separating the marker lights from them. Its pretty easy once you get the trim off though- Josh
1990 325is
Need a shift boot?
Looking to buy shift boot frames, PM if you have one to sell
Here's what happens when you let the internet pick your license plate
It's a cluster fuck and took a few hours doing it blind. The bottom trim piece is held in with these tabs that can be pushed down from above the clips are old BMW plastic. I found if you shine a light down from above you get an idea but its bullshit German overdesign1991 e30 328i M52 swapped: Gone
1995 e34 540i/6 1 of 76 Clean
1985 e28 euro 525i the daily
