School me on E34 fitment
  • isthistherealcaesarspalace
    • Mar 2012
    • 140
    I currently own a e34 540/6 on H&R springs lowered 1.3F 1.0R.
    I want to run 17x9.5 apex arc-8 with 255/40/17 hankook rs3 square setup.
    What do I need to make it happen ie..spacers and so forth
    Picturse will do great thanks r3v!
  • Jb325is
    • 2137
    You'll probably need to roll the fenders and run a spacer on the front to avoid rubbing on the strut housing. What is the offset? It's easily do-able though, I run 17x8 ET-3 and 17x9 ET-5 with 245's and 275's
    - '88 m54 coupe
    <3
      • Mar 2012
      • 140
      the offset is et35
      • Dj Buttchug
        • Jun 2010
        • 7688
        you will FOR SURE need spacers. At least in my experience 17x8 et20 will rub the strut housing unless the offset is corrected to +5 or less. (but this is on BC coils) ride height changes alot.
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • Jb325is
          • 2137
          I'd say to fit those at you'll need about a 20mm spacer in the front, and bigger in the rear just to look right. 255's aren't that big on an e34
          - '88 m54 coupe
          <3
