1988 535is RoyalBlau Euro Conversion Minty
  • scabzzzz
    Estado de mierda de encargo
    • 6871
    **Updated with new pictures and price reduction, see below.**
    Exhaust sound from outside the car
    Video of idle and exhaust sound from inside car. Note the check panel for Brake Lights, only does this occasionally. Brake lights work fine.
    Reluctantly, I'm selling my immaculate E28 in order to fund my main project (2002). This car has been meticulously cared for in its lifetime and has had nothing but the best in service, maintenance, and repair. This would make a great weekend warrior for trips and Cars N Coffee type shows. Very comfortable, has great power left, shifts well, handles great but not too low, and gets a lot of attention when driving.
    Highlights of Good
    -M30B35 | 5 speed with factory LSD
    -Royalblau Metalic with all new OEM euro bumpers and front valance purchased from Bluntech, painted at dealership
    -New tires last month | Contintenal ProContact 205/55/16
    -Sport interior in 7/10 or better shape
    -Newer Magnaflow exhaust with Gibson tips
    -Euro headlight and grill conversion
    -Comes with TONS of additional spare parts and new OEM maintenance parts PLUS crackfree dash, spare euro headlights, OEM mud flaps, etc
    -Heavily documented with receipts and Bentley manual
    -Lowered on Eibach and Bilstein suspension
    -Original spare keys in decent shape
    -Original owners manual
    -Full spare Style 29 included with good Yokohama tire
    Highlights of Bad
    -Cracked dash but has pad installed/ comes with crack free dash not installed
    -Needs replacement front bumper center section or at least touch up paint (new center section included with car unpainted)
    -Needs driver door hinge replacement (NLA) (included with car)
    -Sunroof will not open. Makes clicking noise, have not investigated
    -Small tear in driver seat leg bolster, seat really needs an overhaul in general
    -Central door lock system not operational
    -Driver floor mat needs to be replaced, comes with full set of all weather mats (universal)
    Does need minor odds and ends repaired to be 100% again. The car will be serviced and cleaned before purchase and ready to drive anywhere. Would consider partial trades on 2002 parts plus cash. Car is located in Nashville, TN.
    $8000 obo
    Maintenance Mileage/Date Service Completed
    -Spark Plugs (Bosch Silbers 5/2007
    Distributor Cap and Rotor
    -Beru Plug Wires 5/2007
    -Diff Fluid with Redline 75w90 5/2007
    -Gearbox Oil with Redline MTL 5/2007
    New drive belts 4/2007
    Changed Air Filter 11/14/2010 110000
    Oil and Filter Changed Penzoil 20w50 01/21/2012 125000
    Diff and Trans Fluid checked and topped off 04/21/2011 117500
    02/23/09 100,630 Valves Adjusted (AutoHaus Nashville) 2/23/09 100,630
    Bosch Wiper Blade Replacements
    03/19/09 100,800 Flushed and Filled Coolant (BMW Blue) 3/19/2009 100,800
    03/19/09 100,800 Replaced Thermostat 3/19/2009 100,800
    03/19/09 100,800 Replaced Radiator and Heater Hoses and Clamps and Heater T 3/19/2009 100,800
    03/19/09 100,800 Replaced FanClutch 3/19/2009 100,800
    03/19/09 100,800 Replaced WaterPump and Gasket 3/19/2009 100,800
    -New Balo Rotors (rear) with semi metallic pads 7/2007
    -New Front Rotors and Pads 4/2012 126000
    Clean underhood and other electrical contacts
    Flush brake fluid super blue 4/15/2012 126000
    Tires - 4 Arizonians Silver Edition 4/15/2012 126000
    Oil Change with OEM filter - Valvoline VR4 2/15/2014 uknown mileage
    Tires - Contintental ProContact 205/55/16 10/2014 unknow mileage
    Repairs Completed
    -Main Relay 4/2007
    -Fuel Pump Relay 4/2007
    -New Vacuum lines 5/2007
    -Heater control Valve 12/2007
    -Upper Control Arms with HD bushings 01/2012 125000
    -Replaced the cold start injector hose 12/2007
    -Replaced the interior light bulbs for the dash 1/2008
    -Replaced the oil pan gasket 3/2008
    -New Exhaust system (Custom 2.5” Magnaflow cat and 12646 muffler) in 5/2008
    -Tail light gaskets 8/2008
    -Trunk Gasket 8/2008
    Replaced Drivers Side Foglight Bulb H-3 12/6/08 99,700
    Replaced Breather Hoses under AFM 2/23/09 100,630
    Replaced Coolant Temp Sensor 3/19/09 100,800
    Replaced all 6 injectors (serviced units from CruzinPerformance) 3/19/09 100,800
    Replaced AC Condensor Hose 5/2009
    AC (replace dryer, pull vaccum, charge with coolant) 7/2010
    Replaced Tie Rod Ends Lemforder 105600 8/2010
    Replaced Centerlink Meyle 105600 8/2010
    Replaced Idler Arm 105600 8/2010
    Installed steering box reinforcement awaiting welding 105600 8/2010
    Replaced Vapor Tank fuel hoses 109000 11/1/2010
    Replaced Gas Cap with OE 109823 11/10/10
    Adjusted TPS and throttle plate. Cleaned 110573 11/20/10
    Passenger Side Front Caliper Rebuilt 114500 02/10/11
    Lower Control Arms Meyle HD 117000 3/23/11
    Sway Bar Links Front 117000 3/23/11
    Front Strut Mounts 117000 3/23/11
    30 Amp Inline fuse wired for Aux Fan 126000 4/10/12
    Replaced diagnostic port cap
    New battery w/ 2 year warranty 2/1/2014
    Coolant flush and inspection - OEM BMW Coolant Oct-14
    Repairs Needed
    Clean all window regulators
    Central Locking not working at all
    Door hinge repair driver side
    Troubleshoot sunroof clicking/malfunction
    A/C recharge with Freeze12
    Fuel filter
    Inspect/replace spark plugs
    Rip in driver seat left bolster
    OBC display bulb replacement
    Ebrake adjustment
    Swap crack free dash in
    Weld steering box bolt
    Source replacement Style 29 center cap
    Paint chipping on front bumper, paint and replace center section
    Upgrades Completed
    Euro Conversion (Bumpers,Valance,Headlights) 6/2009
    Full Paint and Body work Factory color Royal Blau 6/2009
    New BMW OE Windshield (New Gaskets, and Lock Strips) 6/2009
    New BMW Roundels Hood and Trunk 6/2009
    New Outer Windows Squeeges 6/2009
    E39 BBS Style 29 Wheels with matching spare
    Eibach Sport Springs with Bilstein Sports
    Unknown brand front strut bar
  • getouth
    • Jan 2010
    • 3343
    solid deal here!
    FEEDBACK:
    http://www.r3vlimited.com/board/showthread.php?t=316212
    BMWCCA #398608
    IG @yagayo38
    "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
    • scabzzzz
      • 6871
      Originally posted by getouth
      solid deal here!
      Thanks!
      • E30NJ
        • Aug 2013
        • 921
        You'll get what you are looking for, that car is CLEAN!
        • South26
          • Jun 2011
          • 856
          Interior pics would be nice. Also what color? From what I can see I am guessing Pearl Beige, but could also be Llama.
          Andy
          • Eufonik
            • Feb 2014
            • 459
            Sigh... I would also like to own an e28. Very clean! GLWS!
            Instagram @prsvere88
            Transaction Feedback
            • scabzzzz
              • 6871
              Hope so! Thanks man
              Andy
              You're right. ITs Llama. See above. I'm posting a shit load more info like I should ahve done originally.
              Gimmee ur E30 then! ;)
              • South26
                • Jun 2011
                • 856
                Nice Interior.
                Good luck with Sale.
                Andy
                • artoo93
                  • 909
                  If we could sell the wife's van quick, I would be all over this and you are pretty close for once! Most vehicles I want are usually on one coast or the other. Not a hour away!!! Beautiful ride!!!
                  Some people just need a sympathetic pat...
                  on the head...
                  WITH A HAMMER!!!
                  • scabzzzz
                    • 6871
                    Thanks man. If you want to work something out, I'd be happy to. I've had a ton of interest in it, but everyone is cross country. Id really prefer to deal with a local. Let me know!
                    Also accepting partial trades on bang bang items if that helps.
                    • scabzzzz
                      • 6871
                      Updated original post, cleaned up some info and added more, with a price drop for r3v members
                      • Eufonik
                        • Feb 2014
                        • 459
                        Haha, damn. When I saw your reply, it really got me to pause and think for a moment about a trade, but I really love this little guy. I'm saving up to get myself a 5spd swap. GLWS again haha!
                        • N2MYE30
                          • Oct 2007
                          • 5536
                          What a frickin nice car! I would really like to add this to my stable...if I had the space. Someone is getting a nice car.
                          COTM
