Seeing as I don't have a garage to place my car, and not a whole lot of time to spend on her, i feel that it's time to find a new home for my 6. Saddens me, but I just don't have the time, which is a tragedy.
Schwarz on cherry, but fronts are cardinal color seats from an e30. 5speed, 3.46 LSD, good old m30b32, runs great, but still hunting down slightly high idle.
As of 8 months ago, the following has been replaced:
-powerflex rear subframe bushings
-New dogbones
-Rear pads and rotors
-Swapped out old 3.25 for a 3.46LSD.
-Driveline replaced with unit that has greasable ujoints
-new(lightly used from an 88 M6) gray carpet, with new padding
-upper thrust arms with 750il bushings.
-coolant temp sensor
-ICV
-thermostat
-radiator hoses( upper, lower, heater hoses, and back of head coolant pipe)
-coolant flush
-brake flush
-new trans fluid
-new diff fluid
-valve adjust
-bosch silver plugs
-new plug wires
-ignition upgrade(changed from slip on rotor to bolt on rotor, with new cap)
-16x7.5 MSW CERES et11, with 205/55 fronts and 225/55 rears. They are painted gold with machined lip and clear coated. Wheels are in great shape, and clean up nice.
-two air dams. One factory, and one from an 85 635csi with fogs. Fogs are shot.
- clutch feels great
- adjustable clutch stop
Car would benefit from:
-two tires, the rears are just on the wear bars
-Odo just stopped, but I have gears to replace. I will replace the gears.
-paint is great on one side, but not the other, past owner says a car scraped the driver side, and was re painted, but it was done not so well. No rust in the repair spot, just bad paint.
-there is only one spot of rust, and that is in the tail light corner. Rust has gone through, but I've por-15'd the spot, and hasn't spread in the 4 years I've had it.
-driver rear window won't go down
-sunroof out of allignment, doesn't leak water, but a little off.
-hood needs repainting
-front nose needs repainting. Both are chipped badly from PO driving from Bellingham to Tacoma a few times a week
-needs an alternator bushing
- there was no air con attached to the car, but I have a rebuilt compressor that will go with it.
- HVAC heat blower only works on high.
Needs shifter bushings.
The car is in good shape and was my daily. I just feel someone else can enjoy her far more then I can.
Asking 2800 obo.
-New dogbones
-ICV
-thermostat
-coolant flush
-brake flush
-new trans fluid
-new diff fluid
-valve adjust
-bosch silver plugs
-new plug wires
Asking 2800 obo.
