Is everyone interested in front and rear or just front? only cause rear is somewhat of a coilover set up.
E28 Coilover suspension DIY (in progress)
Originally posted by downernsp View PostIs everyone interested in front and rear or just front? only cause rear is somewhat of a coilover set up.
That said, I would also like to know what shocks will work for the rear, just standard E28 Koni Yellows?
This thread is exactly what I need. I finally decided to do a decent suspension setup rather cut springs and blown shocks ha. I just need someone to spoon feed me what shocks I should get, what and where I should get the sleeves, and which springs I should get including spring height and rate.
Originally posted by iamcreepingdeath View Postalso: Do E28s and E34s share the same suspension components? As in are the shocks interchangeable? Is the suspension interchangeable between chassies? (wtf is the plural of "chassis"?)
I have heard of the E34 540i brake upgrade to an E28, so obviously something swaps over...
Brakes from a plethora of cars are interchangeable to the E28, including the E31 and E32. The most common upgrade is to take E32 750iL front brakes with E34 540i rear brakes. They all bolt right up, as long as you have the carriers and all other associated hardware.
Some people put in the E32 master cylinder for better feel, but I didn't find it necessary when I swapped in the aforementioned brakes.
Here's a good FAQ about what will fit the E34/E28/E24, brake-wise:
Originally posted by latinobimmer View PostAFAIK, only the rear shocks are interchangeable, but the E34 ones are longer so they will make the E28 sit higher.
http://www.bmwe34.net/E34main/Upgrade/Brakes.htm
I assume also that E34 540i front brakes will fit on an E28?
It will donate the brakes/hubs, remote brake booster, wheels, and M60B40 to my '85 520i.
Originally posted by latinobimmer View PostOkely dokely. I definitely saw on Realoem that the E28 has 82mm and E34 83mm, but it must've been referring to something else hub-related
about halfway down the page here it says what the E28 hub diameter is: http://www.scrappycrow.com/e28wheels...eelstires.html
Near the bottom of this page is talks about E34 hub diameter: http://www.bmwe34.net/E34main/Upgrad...ls_upgrade.htm
