E28 Coilover suspension DIY (in progress)
  • latinobimmer
    • 226
    #61
    Be careful with E31 brakes. Some of them require 17in wheels.
    • AsharC
      • Jun 2011
      • 1508
      #62
      Mine clear fine with 16" style 5s.
      BUY MY WHEELS! BBS E50s!!
      http://www.r3vlimited.com/board/showthread.php?t=275407
      Originally posted by Lurker27
      Any man will tell you being blown is better than being stroked.
      • Eric
        • 5141
        #63
        do you have the single piston ate calipers or the big aluminum 4 piston brembo's?
        Sam - I believe you can use E34 struts just fine. Put E28 top hats on the rear, and for the front, you have to use E34 dogbones (part bolted to the bottom of the strut) and E34 suspension parts (tie rods/control arms etc)
        I have a front and rear left side KW coil overs that you can play around with, but i'd need them back!
        • iamsam
          • Jun 2008
          • 174
          #64
          totally awesome proposition here!
          Problem is, I sold my E34 parts car, since I am looking for a lower mileage alusil M60, not a nikasil w/ 200k on it.
          So when I pick up another E34 or E32, I just might take you up on your offer!
          • BavarianAddict06
            • Sep 2011
            • 315
            #65
            Originally posted by M20_fiend
            my friends e28 535i is on coilovers that he found on ebay (they were made an EF, but i guess the spring rate, and width is right) and it put a pretty agressive drop on it.... but the adjusters were too small to fit around the struts.... so he has no adjusters in the front. No shortened struts or anything.... and he still has problems going into driveways...
            those cars arent really made for being slammed (in my opinion)
            Shut up ro ro. haha. e28s shudnt be slammed? i seee... lol:hitler:
            1987 528i Royalblau
            • einstein57
              • Jun 2007
              • 10780
              #66
              AJ can slam his car if he wants to :up:
              www.gecoils.com
              • AsharC
                • Jun 2011
                • 1508
                #67
                I have the big 4 piston brembo's.
                • aje28
                  • 572
                  #68
                  haha I just saw this post! thanks again for the coils! :grin:
                  • einstein57
                    • Jun 2007
                    • 10780
                    #69
                    Post pics
                    www.gecoils.com
                    • Eric
                      • 5141
                      #70
                      Good to know! Both sets if 16'sthe I've tried to fit don't clear... time to start craigslist hunting!
                      • einstein57
                        • Jun 2007
                        • 10780
                        #71
                        www.gecoils.com
                        • ohthejosh
                          • 4963
                          #72
                          ^That makes me want a e28!
                          SO MUCH MORE TO DO!!
                          IG: ohthejosh
                          LEGIT CHECK ME BRUH
                          BUYER FEEDBACK THREAD
                          • AutoXinE30
                            • Aug 2007
                            • 277
                            #73
                            Sooo, did we ever figure out rear shock options? What rear Koni does GC use in the E28 set up? As I thought E28 Rear Koni's were NLA.
                            If IX housings can be used in the front, any insert used on an E30 should work with the E28 with the appropriate spacer/shortening...
                            • einstein57
                              • Jun 2007
                              • 10780
                              #74
                              Held up an e30 insert next to the e28 and the e30 was about an inch shorter. Food for thought.
                              www.gecoils.com
                              • iamsam
                                • Jun 2008
                                • 174
                                #75
                                So that's good! That means you can shorten the E28 strut housings for coilovers w/ E30 shocks.
