Be careful with E31 brakes. Some of them require 17in wheels.
E28 Coilover suspension DIY (in progress)
Mine clear fine with 16" style 5s.
BUY MY WHEELS! BBS E50s!!
http://www.r3vlimited.com/board/showthread.php?t=275407
Originally posted by Lurker27Any man will tell you being blown is better than being stroked.
Originally posted by latinobimmer View PostBe careful with E31 brakes. Some of them require 17in wheels.Originally posted by 86 325e View PostMine clear fine with 16" style 5s.
Sam - I believe you can use E34 struts just fine. Put E28 top hats on the rear, and for the front, you have to use E34 dogbones (part bolted to the bottom of the strut) and E34 suspension parts (tie rods/control arms etc)
I have a front and rear left side KW coil overs that you can play around with, but i'd need them back!
Problem is, I sold my E34 parts car, since I am looking for a lower mileage alusil M60, not a nikasil w/ 200k on it.
So when I pick up another E34 or E32, I just might take you up on your offer!
Originally posted by M20_fiend View Postmy friends e28 535i is on coilovers that he found on ebay (they were made an EF, but i guess the spring rate, and width is right) and it put a pretty agressive drop on it.... but the adjusters were too small to fit around the struts.... so he has no adjusters in the front. No shortened struts or anything.... and he still has problems going into driveways...
those cars arent really made for being slammed (in my opinion)
Shut up ro ro. haha. e28s shudnt be slammed? i seee... lol:hitler:
AJ can slam his car if he wants to :up:Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
Originally posted by Eric View Postdo you have the single piston ate calipers or the big aluminum 4 piston brembo's?
Post picsYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
Originally posted by 86 325e View PostI have the big 4 piston brembo's.
www.gecoils.com
Held up an e30 insert next to the e28 and the e30 was about an inch shorter. Food for thought.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
