E28 Coilover suspension DIY (in progress)
  • 5Toes
    • 9836
    #121
    How does one know if the spring collars will fit our strut tubes..? or do you just make an adapter to weld on that is the right size?
    I am very intested in this!
    • slammin.e28
      שמע ישראל
      • 12054
      #122
      You grind down the stock strut collar and just leave a bit there. Or you can get a donut to put around the tube and weld it on.
      • cheapshot
        • 451
        #123
        Originally posted by iamcreepingdeath
        Hmm this is very very good info. So I assume the ebay honda coilover sleeves fit fine on the E28 strut bodies?
        Also, do you have pics of the process?
        Use a flapper wheel on a grinder to clearance the top of the strut so the sleeve fits tight. It will want to go onto it without this but it hangs up. I would not recommend using a grinder wheel as you may wind up taking to much off.
        • 5Toes
          • 9836
          #124
          So basically honda covic strut tubes are the same circumference/diameter as BMW ones?
          • slammin.e28
            שמע ישראל
            • 12054
            #125
            That would be a good deduction to take from this.
            I'm loving this, lol. Gonna slam the GF's red IS ^_^
            • iamsam
              • Jun 2008
              • 174
              #126
              all right all right!
              Ok so the civic threaded tubes fit over the BMW stuff. Case closed.
              • cheapshot
                • 451
                #127
                Remember!!!!!!
                • cheapshot
                  • 451
                  #128
                  Do it mang!! I should have taken you for a ride in my e24 when you were down here. It would have you sold. We also finished up that e30 in the garage with the same coil setup, just g60's in the front and camaro gas-a-just in the rear and hot damn does that thing ride good!!!!!!!!!! I am hopefully gonna have the e21 completed this week with the same concept.
                  • iamsam
                    • Jun 2008
                    • 174
                    #129
                    So would billy sports be insufficient damping for these honda coilovers?
                    • cheapshot
                      • 451
                      #130
                      They would be more than adequate.
                      • cheapshot
                        • 451
                        #131
                        The picture here is a bit dark but you can see where we are grinding down the top of the strut tube with a flapper disk and where the spring perch has been cut down for the collar to rest.
                        • iamsam
                          • Jun 2008
                          • 174
                          #132
                          more pics?
                          • slammin.e28
                            שמע ישראל
                            • 12054
                            #133
                            And note, this works for EVERYTHING. They are all the same size diameter. E12 based stuff e28 based, and e30 based too. Shit, even E3s are the same. Everything should fit to drop these motherfuckers to the frame.
                            • cheapshot
                              • 451
                              #134
                              more pics?
                              Thats all I have right now. I will be pulling it down in a few weeks to put in the custom valved billy struts and will get more pics then. I will also be doing my e21 this week and it is the same concept and will take more detailed pictures then.
                              • cheapshot
                                • 451
                                #135
                                I used e30 strut inserts but only bc I got such a good deal on them. Anything you can use for an e03 i.e. g60, ix, mr2 rears, etc. will work as well. Just add 1/2" to 3/4" over the difference they would be in an e30.
