This noise was present before and now after replacing ALL of the following:
- all 4 trailing arm bushings (had a shop press the old ones out and press new oem bushings in)
- new subframe bushings pressed in with the factory tool
- front + 2 side diff bushings
- rear upper subframe bushing
- rsm's
- lower "dog bone" trailing arm-to-subframe bushing
ALL parts installed were OEM new, Lemf/Meyle HD parts only.
Rear shocks are used Billy HD from e28, used with H&R Sport springs. Upper/lower spring pads present, new bump stops, new RSMs.
All the mounting points have been tightened with a torque wrench per the shop manual, and the trailing arm bushings were torqued t 77Nm with the car Level on the ramps.
Any ideas before I push this car off the cliff?
This noise is present when driving at low/medium speeds, straight or turning (more so). I've been able to duplicate it now by basically pushing down on the trunk area.
I've rulled out it being the exhaust, so it's either something with the trailing arm or subframe or something else I am not seeing...
Anybody?
- rsm's
Anybody?
