It's an 86 528e the car is straight, interior is good and everything works! I paid 280 bucks! The only problem is it stalls out under load if you rev the car it's fine if you try to drive the car it dies.
The motor sounds great when it does run.
I was told it needs a new fuel pump but that doesn't seem right to me. I have another e28 that needs a heater core an d a lot of other stuff so in the meantime I can pull parts off it to figure this out. And then buy new parts when I figure out what's wrong.
I plan on trying dme, icm icv and checking grounds if none of this works I will the fuel pump. Am I going on the right direction?
