e12 shorter struts for coilovers
  • cheapshot
    • 451
    Anyone know what other struts can be used with shortened housings for an e12? Or does anyone have any laying around that they can measure the length of the shock body and OD?
  • cheapshot
    • 451
    In case anyone is wondering, I just got off the phone with Bilstein and it turns out that the OD and strut body length is the EXACT same measurements as an e30 strut. Which in turn means that you can use ix or Vw g60 struts, theoretically. I will update this after I get them in and put them together.
    • iamsam
      • Jun 2008
      • 174
      doesn't that make them the same OD and length as the E28 strut as well?
      because iirc, the E30 front inserts work in an E28.
      • slammin.e28
        שמע ישראל
        • 12054
        e30 ones are a tad shorter, no? The diameter is the same from e3s up to e30s, and everything in between.
        43mm, as per the retaining screw at the top. 31 32 1 117 376
        • cheapshot
          • 451
          Correct, they are just under an inch shorter than the e28 strut.
          • iamsam
            • Jun 2008
            • 174
            ok, so what about shock diameter? Same for E30 and E28? Is that what you mean by "e3 up to e30"? as in literally numerically from the numbers 3 to 30? (as in E28?)
            • slammin.e28
              שמע ישראל
              • 12054
              Pretty much.
              E12: Details on E12
              E12 528i Sedan
              E12 530i Sedan
              E23: Details on E23
              E23 733i Sedan
              E23 735i Sedan
              E24: Details on E24
              E24 630CSi Coupe
              E24 633CSi Coupe
              E24 635CSi Coupe
              E24 M6 Coupe
              E28: Details on E28
              E28 524td Sedan
              E28 528e Sedan
              E28 533i Sedan
              E28 535i Sedan
              E28 M5 Sedan
              E3: Details on E3
              E3 2500 Sedan
              E3 2800 Sedan
              E3 2800Bav Sedan
              E3 3.0S Sedan
              E3 3.0SBav Sedan
              E3 3.0Si Sedan
              E30: Details on E30
              E30 318i Convertible
              E30 325i Convertible
              E30 318i Sedan
              E30 318i Coupe
              E30 318is Coupe
              E30 325e Coupe
              E30 325e Sedan
              E30 325i Sedan
              E30 325i Coupe
              E30 325ix Coupe
              E30 325ix Sedan
              E30 M3 Coupe
