I tested all sensors and just got a used ecu since some burnt contacts in it. On the test drive I was doing some panic stops and everything was working great. But, after 3 or so stops for some reason the left front wheel is locking up, but every other wheel is functioning normally. I even found a road with a soft shoulder so I could have one side of the car on asphalt and the other side on gravel/dirt to confirm this. The ABS light does not come on like there is something wrong on the ecu at anytime....just when you first star the car and then goes out.
I see in the diagram the are solonoids for each wheel in the pump housing? Im guessing these aren't serviceable? Any other ideas?
