Weird Charging Issue. Boost after 3k rpm. NEED HELP ASAP
  • AsharC
    • Jun 2011
    • 1508
    Hey guys,
    My cars charging system has been acting weird lately. Once you start the car, everything slowly dies out and once you rev the engine to around 3k RPM and everything is back to normal. What is going on? I replaced the alternator and the battery is next on the list.
    What else can it be?
    Thanks for any help
    BUY MY WHEELS! BBS E50s!!
    http://www.r3vlimited.com/board/showthread.php?t=275407
    Originally posted by Lurker27
    Any man will tell you being blown is better than being stroked.
  • oldmann
    • 265
    Have you ckd for a good ground from alt to chassis.
    Use a jumper cable clamped to alt and chassis, if problem is gone that was it. (Replace ground from alt to engine, engine to chassis)
    • yert315
      • 2734
      May sound stupid, but Make sure your belt is on tight.
      • ethrty
        • Nov 2009
        • 342
        +1 to above diagnostics.
        also, was the alternator you replaced it with known to be good and bench tested under your ownership? certainly wouldn't be the first time that someone has replaced a part and ruled it out just because they replaced it.
        • AsharC
          • Jun 2011
          • 1508
          I'll check the ground. The alternator was rebuilt, it was bench tested also.
