E32 trailing arms onto an E28
  • mar1t1me
    • Sep 2009
    • 863
    Thanks. I have that set of wheels and because tire cross sections vary within specified sizes, my Michelin Exalto PE2 tires in 225/50/16 require a spacer in front, but don't rub in the rear. My other set of Borbet Type A's with ET20 running BS 970AS tires doesn't rub anywhere. I think I could run those without rolling. This seems like a worthwhile mod...thanks!
    • iamsam
      • Jun 2008
      • 173
      yep, if you ever do subframe bushings, I recommend slapping in E32 trailing arms while you are at it. the bigger brakes and sliding ball bearings are worth it.
